HP 3115m Notebook PC - Removing and Replacing the Memory Module
This document is provided to assist in removing and replacing the memory module for the HP 3115m Notebook PC.
Minimum skill level
Tools required
  • Small, flat-bladed screwdriver or a flat-bladed alignment tool
  • Tweezers
Parts required
The replacement part number will vary depending on the memory module that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
4GB, 1333-MHz, PC3-10600, CL=9, DDR3-1333 Dual In-Line Memory Module (Shared)
621569-001
Yes
2GB, 1333-MHz, PC3-10600 memory module (Shared)
621565-001
Yes
For customers in countries/regions with RoHS legislation* (e.g. EU, China, etc.) restricting the use of hazardous substances in electrical equipment. The use of the Original Spare part is regulated by RoHS legislation. If your unit contains a part that is labeled with the Modified Spare number, the Modified Spare must be ordered as the replacement part. If your unit contains a part that is labeled with the Original Spare number, please order the Original Spare as the replacement part. In this case either the Original Spare or the Modified Spare may be shipped which will not affect performance or functionality of the unit.
Summary of instructions
To view a video demonstrating the procedure for removing the memory module, click on the link below. Or use the product video listing on the HP Services Media Library, (Click here to go to HP Service Media Library) then select Memory module from the menu on the upper left hand side of the screen.
Click here to view the memory module removal video (right-click on the link to open in a new window/tab).
Memory module removal
  2.   note:
    The following video depicts a specific configuration of the notebook. The same removal and replacement procedures apply to all configurations of the notebook.
  3.   note:
    The primary and expansion memory slots are both located under the rear accessory cover. The primary memory slot is located on the left and the expansion memory slot is located on the right.
    Push both arms outward simultaneously to release the memory module to the spring tension position.
  4.   caution:
    When handling a memory module, use care to prevent touching the memory chips on the board. Touching the memory chips could damage or destroy the memory. Click here for instruction on "How Can You Prevent Damage to Memory Modules?".
    Grasp the memory module by the edges and pull gently to remove it.
  5. Place the memory module in a static dissipative bag.
Memory module replacement
  1. Grasp the memory module by the edges and remove it from the static dissipative bag.
  2. Align the notch in the memory module with the key in the memory module slot on the system board.
  3. At an angle, gently insert the memory module into its slot on the system board.
  4.   caution:
    Press the memory module down to latch the arms.
Country: Flag Bulgaria
