    Fix Windows 10 Update Issues
HP Pavilion g6-2006ax Notebook PC Product Specifications
Product Name
g6-2006AX
US Product Number
B3K17PA
3 GHz/2.6 GHz AMD Dual-Core A6-4400M
Microprocessor Cache
1 MB L2 Cache
Memory
4 GB 1333 MHz DDR3
Memory Max
Supports up to 8 GB DDR3
Video Graphics
AMD Radeon HD 7670M
Video Memory
1 GB GDDR3 dedicated
Hard Drive
500 GB SATA (5400 rpm)
Multimedia Drive
SuperMulti 8X DVD±R/RW with Double Layer Support
15.6" diagonal HD BrightView LED-backlit Display (1366 x 768)
Network Card
Integrated 10/100 BASE-T Ethernet LAN (RJ-45 connector)
Wireless Connectivity
802.11b/g/n
Sound
Altec Lansing Dual Speakers
PC Card Slots
  • Support SD/SDHC/SDxC, and MMC Supports mini versions of SD/MMC/MS adapters (adapter is not included) (note: SDxC support for capacity only, not speed)
External Ports
  • 1 VGA
  • 1 HDMI
  • 1 USB 2.0
  • 2 USB 3.0
  • 1 RJ-45 / Ethernet
  • 1 External Headphone-out
  • 1 External Microphone input
Dimensions
37.6 x 24.4 x 3.63 cm
Starting at 2.48 kg
Security
Kensington MicroSaver lock slot
Power
  • 6-cell Lithium-Ion (Li-Ion)
ID Mech Description
Webcam with Integrated Digital Microphone (VGA)
Operating System:
Genuine Windows 7 Home Premium (64-bit)
