HP Z620 Workstation - Removing and Replacing Memory Fan
This document is provided to assist in removing and replacing the memory fan for the HP P6000 Enterprise Virtual Array Systems.
Minimum skill level
Parts required
The replacement part number will vary depending on the memory fan that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Memory modules fans assembly
683765-001 (Modified)
Yes
For customers in countries/regions with RoHS legislation (e.g. EU, China, etc.) restricting the use of hazardous substances in electrical equipment. The use of the "Original" spare part is regulated by RoHS legislation. If the unit contains a part that is labeled with the "Modified" spare number, the "Modified" spare part must be ordered as the replacement part. If the unit contains a part that is labeled with the "Original" spare number, please order the "Original" spare number as the replacement part. In this case, either the "Original" or the "Modified" spare number may be shipped which will not affect performance or functionality of the unit.
Summary of instructions
To view a video demonstrating the procedure for removing the memory fan, click here to view the HP Services Media Library and then click on Remove/Replace videos. On the new window, select Memory fan from the menu on the upper left hand side of the screen.
Memory fan removal
This video was developed using a pre-production version of the workstation. The chassis and parts shown might not exactly match the current production version, but the part removal and replacement steps are the same.
    Failure to comply with the precautions could result in damage to the product or loss of data.
  2. Press and hold the two release latches near both ends of the assembly.
  3. Pull the assembly straight up and out of the chassis.
Memory fan replacement
  1. Align the guide tabs on the front of the assembly with the slots on the power supply compartment and optical drive cage.
  2. Lower the assembly into the chassis and push down until the latches snap into place and the assembly is fully seated.
  3.   note:
    Please refer to the product-specific maintenance and service guide at for any future technical information and/or installation guidelines for this component. Click here to refer the product-specific maintenance and service guide.
