HP Z620 Workstation - Removing and Replacing Lower Front Bezel
This document is provided to assist in removing and replacing the lower front bezel for the HP Z620 Workstation.
Minimum skill level
Parts required
The replacement part number will vary depending on the lower front bezel that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Front lower panel assembly
683770-001 (Modified)
Yes
For customers in countries/regions with RoHS legislation (e.g. EU, China, etc.) restricting the use of hazardous substances in electrical equipment. The use of the "Original" spare part is regulated by RoHS legislation. If the unit contains a part that is labeled with the "Modified" spare number, the "Modified" spare part must be ordered as the replacement part. If the unit contains a part that is labeled with the "Original" spare number, please order the "Original" spare number as the replacement part. In this case, either the "Original" or the "Modified" spare number may be shipped which will not affect performance or functionality of the unit.
Summary of instructions
To view a video demonstrating the procedure for removing the lower front bezel, click here to view the HP Services Media Library and then click on Remove/Replace videos. On the new window, select Lower front bezel from the menu on the upper left hand side of the screen.
Lower front bezel removal
This video was developed using a pre-production version of the workstation. The chassis and parts shown might not exactly match the current production version, but the part removal and replacement steps are the same.
    Failure to comply with the precautions could result in damage to the product or loss of data.
  2. Pull out on the two retaining tabs that secure the lower front bezel to the bottom of the chassis.
  3. Rotate the bezel away from the chassis and remove it.
Lower front bezel replacement
  1. Insert the three tabs at the top of the lower front bezel into the slots on the front of the chassis below the drive bays.
  2. Rotate the lower part of the bezel against the chassis and push until the tabs snap into place.
  3.   note:
    Please refer to the product-specific maintenance and service guide at for any future technical information and/or installation guidelines for this component. Click here to refer the product-specific maintenance and service guide.
Country: Flag Bulgaria
