    Looking for Site Help?
HP Z820 Workstation - Removing and Replacing the Access Panel
This document is provided to assist in removing and replacing the access panel for the HP Z820 Workstation.
Minimum skill level
The end user requires no hardware-specific training to replace the defective part. The end user should have familiarity with system hardware and software requiring repair.
Parts required
The replacement part number will vary depending on the access panel that is being replaced. If a part is listed as "Yes" under "Requires Return", then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Left Side Panel Assembly
684572-001 (Modified)
Yes
For customers in countries/regions with RoHS legislation (e.g. EU, China, etc.) restricting the use of hazardous substances in electrical equipment. The use of the "Original" spare part is regulated by RoHS legislation. If the unit contains a part that is labeled with the "Modified" spare number, the "Modified" spare part must be ordered as the replacement part. If the unit contains a part that is labeled with the "Original" spare number, please order the "Original" spare number as the replacement part. In this case, either the "Original" or the "Modified" spare number may be shipped which will not affect performance or functionality of the unit.
Summary of instructions
To view a video demonstrating the procedure for removing the access panel, click here to view the HP Services Media Library and then click on Remove/Replace videos. On the new window, select Access panel from the menu on the upper left hand side of the screen.
Access panel removal
    Failure to comply with the precautions could result in damage to the product or loss of data.
  2. If the key lock on the access panel is in the locked position, use the key to unlock it before removing the access panel.
  3. Pull out and hold the access panel release latch.
  4. Lift the panel away from the chassis.
Access panel replacement
  1. Place the access panel on the bottom chassis guide rail.
  2. Rotate the panel up until it meets the chassis.
  3. Push the access panel against the chassis until it snaps into place.
Please refer to the product-specific Maintenance and Service guide for any future technical information and/or installation guidelines for this component. Click here to access product-specific Maintenance and Service guide.
Country: Flag Bulgaria
