HP Z420 Workstation - Removing and Replacing the Media Card Reader
This document is provided to assist in removing and replacing the media card reader for the HP Z420 Workstation.
Minimum skill level
The end user requires no hardware-specific training to replace the defective part. The end user should have familiarity with system hardware and software requiring repair.
Parts required
The replacement part number will vary depending on the media card reader that is being replaced. If a part is listed as "Yes" under "Requires Return", then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
22-in-1, 3.5-inch form factor, Jack Black (JB) color media card reader
636166-001 (Modified)
Yes
For customers in countries/regions with RoHS legislation (e.g. EU, China, etc.) restricting the use of hazardous substances in electrical equipment. The use of the "Original" spare part is regulated by RoHS legislation. If the unit contains a part that is labeled with the "Modified" spare number, the "Modified" spare part must be ordered as the replacement part. If the unit contains a part that is labeled with the "Original" spare number, please order the "Original" spare number as the replacement part. In this case, either the "Original" or the "Modified" spare number may be shipped which will not affect performance or functionality of the unit.
Summary of instructions
To view a video demonstrating the procedure for removing the media card reader, click here to view the HP Services Media Library and then click on Remove/Replace videos. On the new window, select Media card reader from the menu on the upper left hand side of the screen.
Media card reader removal
    Failure to comply with the precautions could result in damage to the product or loss of data.
  2. Disconnect the media card reader cable from the system board.
  3. Pull out on the release latch and slide the drive carrier out of the drive cage.
    In a desktop configuration, push in on the drive lock to release the drive carrier.
  4. Press the green release latch on the drive carrier and slide the media card reader back about an inch.
  5. Lift the media card reader up and out of the carrier.
    If the replacement media card reader does not include guide screws, remove and reuse the screws from this drive.
Media card reader replacement
  1. Place the media card reader into the drive carrier.
  2. Push the media card reader into the drive carrier until it locks into place.
  3. Push the drive carrier into the drive bay until it locks into place.
  4. Connect the media card reader cable to the system board.
Please refer to the product-specific Maintenance and Service guide for any future technical information and/or installation guidelines for this component. Click here to access product-specific Maintenance and Service guide.
