    Fix Windows 10 Update Issues
Removing and Replacing a Memory Module for HP Pavilion dv6-7000, dv6-7100 and HP ENVY dv6-7200, dv6-7300 Notebook PCs
This document applies to HP Pavilion dv6-7x00 series and HP ENVY dv6-7x00 series notebook computers.
HP dv6-7x00 series notebook computer
Before you begin
  • Turn off the computer. Disconnect the Ethernet or modem cable. Disconnect the power cord.
  warning:
  warning:
Before starting, power off the computer and wait for components to cool before starting these procedures.
This product contains components that can be damaged by electrostatic discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, use a static dissipative work surface (such as a conductive foam pad), and wear an ESD wrist strap connected to a grounded surface.
Video overview
Removing a memory module
  warning:
Follow the steps in this section to remove a memory module.
The primary and expansion memory slots are both located under the service door. The primary memory slot is located on the bottom and the expansion memory slot is located on top. Remove an expansion memory module before removing the primary memory module.
Step 1
Remove the battery.
For more information about removing the battery, refer to the HP support document Removing and Replacing the Battery.
Removing the battery
Step 2
Remove the service door.
For more information about removing the service door, refer to the HP support document Removing and Replacing the Service Door.
Removing the service door
Step 3
Push both arms outward simultaneously to release the memory module to the spring tension position.
Pushing the arms outward
Step 4
Grasp the memory module by the edges and pull up gently to remove it.
Use care to not touch the memory chips when handling a memory module. Touching the memory chips could damage or destroy the memory.
Pulling out the RAM
Step 5
Place a memory module in an anti-static bag.
Placing a memory module in anti-static bag
Replacing a memory module
Use the steps in this section to replace a memory module.
Step 1
Align the notch in a memory module with the key in the memory module slot.
Aligning the notch and key
Step 2
Insert a memory module at an angle into the slot.
Inserting the module
Step 3
Press the memory module down until it latches.
Pushing down on the RAM
Step 4
Replace the service door.
For more information about replacing the service door, refer to the HP support document Removing and Replacing the Service Door.
Sliding the service door in
Step 5
Replace the battery.
For more information about replacing the battery, refer to the HP support document Removing and Replacing the Battery.
Pressing down on the battery
