HP PCs - CD or DVD Drive Cannot Burn Discs (Windows 10, 8)
This document is for HP and Compaq computers using Windows 10 or 8.
If you cannot burn music or data to blank CDs or DVDs, follow the steps in this document to resolve the problem.
For business computers, security restrictions might prevent the use of the optical drive for anything other than reading the disk. Contact your company's IT department or your local IT service for more information.
This document assumes that your CD or DVD drive is recognized by Windows and is capable of reading discs. If your disc burning software displays the message No burner is currently available (or similar), or the drive cannot play CDs and DVDs, then this document does not solve the problem. Instead, refer to CD/DVD Drive Is Not Detected (Windows 10, 8).
Step 1: Use a different type of disc
If your computer cannot burn discs, try using a different type of disc. The type of disc you use for burning must be compatible with the type of disc drive in your computer; that is, you cannot burn a DVD-R disc in a drive that does not support DVD-R technology.
For testing purposes, try a few different brands of compact disc recordable (CD-R). CD-R discs are supported by all recordable disc drives.
Why try another disc? There are many different brands and types of writable discs with unique burning properties - some perform better than others. Your disc drive can adjust various properties of the laser and disc rotation to match the properties of the disc, but it might not be able to find a match with some batches of recordable media.
If the drive cannot burn discs of other brands, decrease the disc burning speed.
Step 2: Decrease the disc burning speed
If your computer cannot burn discs, try burning the disc using a slower burn speed. Decrease the burning speed in your disc burning software. When burn speed is reduced it takes longer to complete the disc, but the writing process is more likely to finish successfully and a completed disc has more reliable playback in other devices.
Example: Decreasing the disc burning speed in CyberLink Power2Go
Step 3: Remove the CD/DVD drive from Device Manager
If your computer cannot burn discs, try removing the CD/DVD drive. Follow these steps to remove the drive from Device Manager:
  1. In Windows, search for and open Device Manager.
    Search for Device Manager
  2. Double-click DVD/CD-ROM drives to expand the category.
    Device Manager window showing location of DVD/CD-ROM drives
  3. Right-click the drive name and select Uninstall.
    Device Manager window, uninstall DVD/CD-ROM drive
    If a confirmation window opens, click OK. The drive name should be removed from the list (and the DVD/CD-ROM drives category is removed if there is only one drive). Do not restart the computer and do not refresh the hardware list.
  4. Close Device Manager.
    You must complete the next step before attempting to burn another disc.
Step 4: Clear the registry filters
If your computer cannot burn discs, try clearing the registry filters. To clear the upper and lower registry filters, use the following steps:
  1. Remove all CD/DVD writing software (for example, Cyberlink Power2Go) using the Programs and Features window in Control Panel. For more help, refer to Uninstalling Software (Windows 10, 8).
    Make sure you can reinstall your disc burning software before you uninstall it. To find the software after you uninstall it, use HP Recovery Manager if the burning software came from HP, or use the installation files if the burning software came from another company.
  2. Unplug all non-essential external plug and play devices, especially cameras.
  3. In Windows, search for and open regedit.
    If you are prompted for an Administrator password or confirmation, type the password or provide confirmation.
    Searching for regedit
  4. Select Computer in the main window.
    Registry Editor
  5. Click File, Export, type a filename that is easy for you to remember, and then click Save.
    A copy of the registry is saved for back-up purposes to the Documents folder. If problems occur after using these steps, browse to the file, and then double-click it to restore the registry.
  6. Click the arrow next to the following items in the list to expand the items:
    • HKEY_LOCAL_MACHINE
    • SYSTEM
    • CurrentControlSet
    • Control
    • Class
  7. Select 4D36E965-E325-11CE-BFC1-08002BE10318. Make sure you have selected this exact key name.
  8. If a LowerFilters value is listed on the right side of the registry editor window, select the LowerFilters value and press the Delete key. Confirm the deletion by clicking Yes.
    Registry Editor with LowerFilters value selected
  9. If an UpperFilters value is also listed, select UpperFilters in the right side of the window and press the Delete key. Confirm the deletion by clicking Yes.
  10. Delete all other UpperFilters and LowerFilters values within the 4D36E965-E325-11CE-BFC1-08002BE10318 key if any exist.
  11. Close the Registry Editor, restart the computer, and then wait until Windows configures the necessary drivers for new hardware.
  12. After you remove all CD/DVD writing software, restart the computer and reinstall the software. Depending on the software, you can reinstall from Microsoft, HP, or the manufacturer's website.
    • Check the Microsoft Store. Many of the apps that came pre-installed on your computer are available to download for free in the Microsoft Store app.
    • Go to the HP Customer Support - Software and Driver Downloads page. If a Let's identify your product to get started page displays, select your computer type, type the model name of your computer, and then click Submit. From the list of available software and driver categories, find the software or driver you are looking for, click the category name, and then click Download.
    • Go to the software manufacturer's website.
    For more information and support, go to Issues with Apps in Windows 10.
  13. Try creating a disc again. If you still cannot create a disc that can be read in another drive, use Microsoft System Restore.
Step 5: Use Microsoft System Restore
If the computer still cannot write to the disc, use Microsoft System Restore to go back to a time when the drive was recognized by Windows. For more information about using System Restore, refer to the HP support document Using Microsoft System Restore (Windows 10, 8).
When finished, use the CD/DVD drive again to see if it works. If it works, you are done. If it does not, perform a system recovery.
Step 6: Perform a system reset
If the computer still cannot write to the disc, back up your important files and reset your computer by reinstalling the operating system. Depending on your version of Windows, choose one of the following documents for more information:
When done, use the CD/DVD drive again to see if it can burn a disc. If not, test for CD/DVD hardware failure.
Step 7: Test for CD/DVD drive hardware failure
The laser alignment and the hardware that supports it must retain a high degree of accuracy. As the CD/DVD drive in your computer ages, it is affected by vibration, dust, mechanical wear, and other factors. If the computer still cannot burn discs after performing the other steps in this document, test the drive for hardware failure. For more information about testing for CD/DVD drive hardware failures, go to Testing for Hardware Failures.
If the drive fails the test, replace the drive or have the computer serviced.
