    Fix HP Printer issue on macOS
HP LaserJet Pro 300/400 color MFP M375/M475 Series Product - Create a booklet with Windows
  1. On the File menu in the software program, click Print.
    Figure : File menu
  2. Select the product, and then click the Properties or Preferences button.
    Figure : Print dialog box
  3. Click the Finishing tab.
    Figure : Finishing tab
  4. Select the Print on both sides check box.
  5. In the Booklet layout drop-down list, click the Left binding or Right binding option. The Pages per sheet option automatically changes to 2 pages per sheet.
  6. Retrieve the printed stack from the output bin, and maintaining the same orientation, place it with the printed-side facing down in Tray 1.
    Figure : Paper orientation
  7. On the control panel, touch the OK button to print the second side of the job.
