HP LaserJet Pro 300/400 color MFP M375/M475 Series Product - Interpret Control Panel Messages
Interpret control panel messages for supplies
10.100X Supply Memory Error
A specific print cartridge has a faulty or missing memory chip.
"X" indicates the cartridge: 0=black, 1=cyan, 2=magenta, 3=yellow.
Recommended action
Check the memory chip. If it is broken or damaged, replace the cartridge.
Verify that the cartridge is installed in the correct location.
Reinstall the print cartridge.
Turn off and then turn on the product.
If the error is with a color cartridge, try swapping it with a different color cartridge in the tray. If the same message appears, then there is an engine problem. If a different 10.100X message appears, replace the cartridge.
If the problem is not solved, replace the cartridge.
79 Error Turn off then on
The product has experienced an internal firmware error.
Recommended action
  1. Turn the product power off, wait at least 30 seconds, and then turn the product power on and wait for it to initialize.
  2. If you are using a surge protector, remove it. Plug the product directly into the wall socket. Turn the product power on.
  3. Make sure the printer is running the latest available firmware from HP.com.
  4. If the error is intermittent, attempt to isolate the issue to something specific in your environment.
    1. Delete all print jobs from all computers connected to the printer. Resend the job.
    2. In rare cases, a specific IP address has been seen to cause the error; assign a different IP address to the printer.
  5. If the message persists, contact HP support.
79 Service error Turn off then on
An incompatible DIMM may be installed.
Recommended action
  5. If the issue persists, remove any installed DIMMS and retest.
    1. If the printer prints fine, install a DIMM that the product supports.
  6. If the message persists, contact HP support.
Black Cartridge Low
The print cartridge is nearing the end of its useful life.
Recommended action
Printing can continue, but consider having a replacement supply on hand.
Black in wrong position
The print cartridge is installed in the incorrect slot.
Recommended action
Make sure that each print cartridge is installed in the correct slot. From front to back, the print cartridges are installed in this order: black, cyan, magenta, and yellow.
Black Very Low
The print cartridge is at the end of its useful life. The product continues printing to prevent fax interruptions.
Recommended action
To ensure optimal print quality, HP recommends replacing the print cartridge at this point. You can continue printing until you notice a decrease in print quality. Actual cartridge life may vary.
Once an HP supply has reached very low, HP's premium Protection Warranty on that supply has ended. All print defects or cartridge failures incurred when an HP supply is used in continue at very low mode will not be considered to be defects in materials or workmanship in the supply under the HP Print Cartridge Warranty Statement.
Cyan Cartridge Low
Recommended action
Cyan in wrong position
Recommended action
Cyan Very Low
The print cartridge is at the end of its useful life. When a color print cartridge becomes very low, the product prints in black only to prevent fax interruptions. When you choose to replace the very low print cartridge, color printing resumes automatically.
Recommended action
Genuine HP supply installed
A genuine HP supply was installed.
Recommended action
No action necessary.
Incompatible <color>
You have installed a print cartridge that is intended for use in a different HP product model. The product might not function correctly with this print cartridge installed.
Recommended action
Install the correct print cartridge for this product.
Install [color] cartridge
One of the color cartridges is not installed with the door closed.
Recommended action
Install the indicated color cartridge.
Magenta Cartridge Low
Recommended action
Magenta in wrong position
Recommended action
Magenta Very Low
Recommended action
Remove shipping lock from <color> cartridge
A print cartridge shipping lock is installed.
Recommended action
Pull the orange tab to remove the shipping lock from the cartridge.
Remove shipping locks from cartridges
A print cartridge shipping lock is installed on one or more print cartridges.
Recommended action
Replace [color]
The print cartridge is at the end of its useful life, and the product is customer-configured to stop printing when it reaches the very low state.
Recommended action
Unsupported <color> Press [OK] to continue
The product has detected a print cartridge that was not made by HP.
Recommended action
Press the OK button to continue printing.
If you believe you purchased an HP supply, go to www.hp.com/go/anticounterfeit. Service or repairs that are required as a result of using unsupported supplies is not covered under HP warranty.
Used <color> in use
You are using a print cartridge that reached the default low threshold while it was installed in a product.
Recommended action
Used [color] installed, to accept press OK
A used color print cartridge has been installed or moved.
Recommended action
Touch the OK button to return to the Ready state.
Used supplies in use
You are using more than one print cartridge that reached the default low threshold while it was installed in a product.
Recommended action
Printing can continue, but consider having replacement supplies on hand.
Yellow Cartridge Low
Recommended action
Yellow in wrong position
Recommended action
Yellow Very Low
Recommended action
