    Windows 11 Upgrade Guide
HP LaserJet Pro 300/400 color MFP M375/M475 Series Product - Configure IP network settings with Windows
View or change network settings
Use the embedded Web server to view or change IP configuration settings.
  1. Print a configuration page, and locate the IP address.
    • If you are using IPv4, the IP address contains only digits. It has this format:
      xxx.xxx.xxx.xxx
    • If you are using IPv6, the IP address is a hexadecimal combination of characters and digits. It has a format similar to this:
      xxxx::xxxx:xxxx:xxxx:xxxx
  2. To open the HP Embedded Web Server, type the IP address (IPv4) into the address line of a Web browser. For IPv6, use the protocol established by the Web browser for entering IPv6 addresses.
  3. Click the Networking tab to obtain network information. You can change settings as needed.
Set or change the product password
Use the HP Embedded Web Server to set a password or change an existing password for a product on a network.
  1. Type the product IP address into the address line of a Web browser. Click the Networking tab, and click the Security link.
    If a password has previously been set, you are prompted to type the password. Type the password, and then click the Apply button.
  2. Type the new password in the New Password box and in the Verify password box.
  3. At the bottom of the window, click the Apply button to save the password.
Manually configure IPv4 TCP/IP parameters from the control panel
Use the control-panel menus to manually set an IPv4 address, subnet mask, and default gateway.
  1. Touch the Setup button.
  2. Scroll to and touch the Network Setup menu.
  3. Touch the TCP/IP Config menu, and then touch the Manual button.
  4. Use the numeric keypad to enter the IP address, and touch the OK button. Touch the Yes button to confirm.
  5. Use the numeric keypad to enter the subnet mask, and touch the OK button. Touch the Yes button to confirm.
  6. Use the numeric keypad to enter the default gateway, and touch the OK button. Touch the Yes button to confirm.
Link speed and duplex settings
This information applies only to Ethernet networks. It does not apply to wireless networks.
The link speed and communication mode of the print server must match the network hub. For most situations, leave the product in automatic mode. Incorrect changes to the link speed and duplex settings might prevent the product from communicating with other network devices. If you need to make changes, use the product control panel.
The setting must match with the network product to which you are connecting (a network hub, switch, gateway, router, or computer).
Making changes to these settings causes the product to turn off and then on. Make changes only when the product is idle.
  3. Touch the Link Speed menu.
  4. Select one of the following options.
    Setting
    Automatic
    The print server automatically configures itself for the highest link speed and communication mode allowed on the network.
    10T Half
    10 megabytes per second (Mbps), half-duplex operation
    10T Full
    10 Mbps, full-duplex operation
    100TX Half
    100 Mbps, half-duplex operation
    100TX Full
    100 Mbps, full-duplex operation
  5. Touch the OK button. The product turns off and then on.
