    Windows 11 Upgrade Guide
HP LaserJet Pro 300/400 color MFP M375/M475 Series Product - Install the product on a wireless network with Windows (wireless models only)
Use this procedure if you are not using the HP Smart Install.
Before installing the product software, make sure the product is not connected to the network using a network cable.
If your wireless router does not support Wi-Fi Protected Setup (WPS), obtain the wireless router network settings from your system administrator, or complete the following tasks:
  • Obtain the wireless network name or service set identifier (SSID).
  • Determine the security password or encryption key for the wireless network.
Connect the product to a wireless network using WPS
If your wireless router supports Wi-Fi Protected Setup (WPS), this is the simplest way to set up the product on a wireless network.
  1. From the Home screen on the product control panel, touch the Wireless button.
  2. Touch the Wireless Menu button, and then touch the Wi-Fi Protected Setup button.
  3. Use one of these methods to complete the setup:
    • Pushbutton: Select the Pushbutton option and follow the instructions on the control panel. Establishing the wireless connection can take a few minutes.
    • PIN: Select the Generate PIN option and follow the instructions on the control panel. The product generates a unique PIN, which you must type into the wireless router's setup screen. Establishing the wireless connection can take a few minutes.
If this method is not successful, try using the Wireless Setup Wizard on the product control panel or try using the USB cable connection method.
Connect the product to a wireless network using the Wireless Setup Wizard
If your wireless router does not support WiFi-Protected Setup (WPS), you can use this method to install the product on a wireless network.
  2. Touch the Wireless Menu button, and then touch the Wireless Setup Wizard button.
  3. The product scans for available wireless networks and returns a list of network names (SSIDs). Select the SSID for your wireless router from the list if it is available. If the SSID for your wireless router is not in the list, touch the Enter SSID button. When prompted for the type of network security, select the option that your wireless router uses. A keypad opens on the control panel display.
  4. If your wireless router uses WPA security, type the passphrase on the keypad.
    If your wireless router uses WEP security, type the key on the keypad.
  5. Touch the OK button, and wait while the product establishes a connection with the wireless router. Establishing the wireless connection can take a few minutes.
Connect the product to a wireless network using a USB cable
If your wireless router does not support WiFi-Protected Setup (WPS), use this method to set up the product on a wireless network. Using a USB cable to transfer settings makes setting up a wireless connection easier. After the setup is complete, you can disconnect the USB cable and use the wireless connection.
  1. Insert the software CD into the computer CD tray.
  2. Follow the on-screen instructions. When prompted, select the Connect through a wireless network option. Connect the USB cable to the product when prompted.
    Do not connect the USB cable until the installation program prompts you.
  3. When the installation is complete, print a configuration page to make sure that the product has a SSID name.
  4. When installation is complete, disconnect the USB cable.
Install the software for a wireless product currently on the network
If the product already has an IP address on a wireless network and you want to install product software on a computer, complete the following steps.
  1. From the product control panel, print a configuration page to obtain the product IP address.
  2. Install the software from the CD.
  3. Follow the on-screen instructions.
  4. When prompted, select the Connect through a wireless network option, and then click the Next button.
  5. From the list of available printers, select the printer that has the correct IP address.
