HP LaserJet Pro 300/400 color M351/M451 Series Printer - Understand paper use
This product supports a variety of paper and other print media. Paper or print media that does not meet the following guidelines might cause poor print quality, increased jams, and premature wear on the product.
It is possible for paper to meet all of these guidelines and still not produce satisfactory results. This might be the result of improper handling, unacceptable temperature and/or humidity levels, or other variables over which Hewlett-Packard has no control.
Using paper or print media that does not meet Hewlett-Packard's specifications might cause problems for the product, requiring repair. This repair is not covered by the Hewlett-Packard warranty or service agreements.
  • For best results, use only HP-brand paper and print media designed for laser printers or multiuse.
  • Do not use paper or print media made for inkjet printers.
    HP LaserJet products use fusers to bond dry toner particles to the paper in very precise dots. HP laser paper is designed to withstand this extreme heat. Using inkjet paper could damage the product.
  • Hewlett-Packard Company cannot recommend the use of other brands of media because HP cannot control their quality.
Use the following guidelines to obtain satisfactory results when using special paper or print media. Set the paper type and size in the printer driver to obtain the best results.
Media type
Do
Do not
Envelopes
  • Store envelopes flat.
  • Use envelopes where the seam extends all the way to the corner of the envelope.
  • Use peel-off adhesive strips that are approved for use in laser printers.
  • Do not use envelopes that are wrinkled, nicked, stuck together, or otherwise damaged.
  • Do not use envelopes that have clasps, snaps, windows, or coated linings.
  • Do not use self-stick adhesives or other synthetic materials.
Labels
  • Use only labels that have no exposed backing between them.
  • Use labels that lie flat.
  • Use only full sheets of labels.
  • Do not use labels that have wrinkles or bubbles, or are damaged.
  • Do not print partial sheets of labels.
Transparencies
  • Use only transparencies that are approved for use in color laser printers.
  • Place transparencies on a flat surface after removing them from the product.
  • Do not use transparent print media not approved for laser printers.
Letterhead or preprinted forms
  • Use only letterhead or forms approved for use in laser printers.
  • Do not use raised or metallic letterhead.
Heavy paper
  • Use only heavy paper that is approved for use in laser printers and meets the weight specifications for this product.
  • Do not use paper that is heavier than the recommended media specification for this product unless it is HP paper that has been approved for use in this product.
Glossy or coated paper
  • Use only glossy or coated paper that is approved for use in laser printers.
  • Do not use glossy or coated paper designed for use in inkjet products.
