Document ID: c03131113
Version: 1
HP Notebook PCs - Application and Driver DVD Fails to Install the HP Notebook PC User Guide
Release date : 22-Dec-2011
Last updated : 04-Jan-2012
DESCRIPTION
The Application and Driver DVD (ARDVD) fails to install the HP notebook PC user guide. When attempting to access the user guide from the Windows Help and Support page, the following error message appears:
HP User Guides
This program is not installed. Some programs may not be included with your HP notebook PC.
For example:
sourceInformation
SCOPE
HP ProBook 4520s Notebook PC
RESOLUTION
HP notebook PC user guide is located by default in the C:\SWSetup folder. If you re-partition the hard disk drive or install a custom system image, this folder may be moved or deleted.
Before modifying the HDD structure, back up the C:\SWSetup folder as that includes all factory image drivers and applications for the HP notebook PC, including documentation.
If you no longer have C:\SWSetup folder or you failed to back it up, contact HP Customer Support for a user guide for your HP notebook PC.
Hardware platforms affected : HP ProBook 4520s Notebook PC
Support Communication Cross Reference ID : IA03131068
Country: Flag Bulgaria
