HP 3115m Notebook PC Product Specifications
Product description
Product features
Feature
Intel System Controller Hub (SCH) SM35
Processors1
  • AMD E450 1.65-GHz processor (1.0MB L2 cache, 1333 MHz, dual core, 18 W)
  • AMD E300 1.30-GHz processor (1.0MB L2 cache, 1066 MHz, dual core, 18 W)
Graphics
AMD Radeon HD 6320 discrete-class graphics on computer models equipped with an AMD E450 1.65-GHz processor
Display2
Internal: 8.9-inch diagonal WSVGA touchscreen (1024 x 600):
  • Wide-viewing angle
  • Capacitive multi-touch screen with digitizer
  • Auto rotate (selectable)
  • Anti-glare flushed glass display
  • Anti-fingerprint coating
  • Accelerometer (ST Micro)
External:
  • Up to 32-bit per pixel color depth
  • HDMI port in optional HP Slate Dock supports resolutions up to 1600 x 1200 non-interlaced
Memory3
Standard:
2GB DDR2 on-board memory (not user accessible or ungradable)
Battery
2-cell, 30 Wh polymer (not user replaceable)
Battery life4
Up to 6 hours
Keyboard/pointing devices
97% Duracoat, island-style keyboard, no spill-resistance (in charcoal and linen white finishes)
1: Intel's numbering is not a measurement of higher performance. Processor speed denotes maximum performance mode; processor will run at lower speeds in battery optimization mode.
2: Resolutions are dependent upon monitor capability, and resolution and color depth settings.
3: Memory operates at the maximum system supported speed of 800 MHz.
4: Battery life will vary depending on the product model, configuration, loaded applications, features, use, wireless functionality, and power management settings. The maximum capacity of the battery will naturally decrease with time and usage.
Electrical specifications
Input power
18.5 V dc @ 3.5 A - 65 W
Physical specifications
Dimensions (D x W x H)
215 x 291 x 21.1 front (31.9 rear) mm (8.46 x 11.48 x 0.83 front (1.25 rear) in)
Weight1
  • With 6-cell battery: 1.60 kg (3.53 lb)
  • With 3-cell battery: 1.46 kg (3.22 lb)
1: Weight will vary by configuration.
Software overview
Feature
Operating system (Preinstalled)
  • Windows 7 Home Basic (64 and 32-bit)
  • Windows 7 Home Premium (64 and 32-bit)
  • Windows 7 Professional (64 and 32-bit)
  • Windows 7 Starter 32-bit (only on computer models equipped with 2GB memory)
  • DVD SSRD recovery solution
System may require upgraded and/or separately purchased hardware and/or a DVD drive to install the Windows 7 software and take full advantage of Windows 7 functionality. Click here to access the Microsoft page for details.
Environmental specifications
Operating
Temperature
5° to 35°C (41° to 95°F)
Relative humidity
10% to 90%
Maximum altitude
-15 to 3,048 m (-50 to 10,000 ft)
Non-operating
Temperature
-20° to 60°C (-4° to 140°F)
Relative humidity
5% to 95%
Maximum altitude
-15 to 12,192 m (-50 to 40,000 ft)
Applicable product safety standards specify thermal limits for plastic surfaces. The device operates well within this range of temperatures.
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
