HP Designjet L26500 Printer Series - Overview
Product description
The HP Designjet L26500 Series Printer is a color inkjet printer designed for printing high-quality images on flexible substrates from 0.584 m to 1.55 m wide.
HP Latex Inks are water-based inks that combine the best characteristics of ecosolvent inks and water-based inks. You can obtain the outdoor durability and versatility on low-cost, uncoated papers that you would traditionally associate with eco-solvent inks, together with the odorless prints,(low maintenance, and environmental advantages you get from water-based inks.
HP Latex Inks are completely cured inside the printer to form a durable film on the print medium. Prints come off dry so you can move right on to lamination, finishing, shipping, or display.
Product Features
Feature
  • Print Technology - HP Thermal Inkjet
  • Printing speeds in draft mode of up to 22.8 m²/h
  • Print resolution 1200 x 1200 dpi
  • Environmentally friendly, odorless, aqueous latex inks in six colors
  • Water-based HP Latex Inks—no special ventilation required
  • Ink Colors
    • Cyan
    • Magenta
    • Yellow
    • Black
    • Light Cyan
    • Light Magenta
  • Printheads - 6 (2 x yellow/black, 2 x cyan/light cyan, 2 x light magenta/magenta)
  • 775 ml ink cartridges
  • Print on a wide range of substrates—including most low-cost, uncoated, solvent-compatible substrates
  • Media Types
    • Banners
    • Vinyls
    • Films
    • Fabrics
    • Papers
    • Mesh with Liner
  • A range of HP recyclable substrates is available
  • Durable prints with outdoor display permanence up to three years unlaminated, five years laminated
  • Accurate and consistent color reproduction with automatic color calibration (built-in spectrophotometer) for most substrates
  • ENERGY STAR® qualified product
  • Warranty - One-year limited hardware warranty; 8-hour, 5 days a week phone support
Software Overview
Feature
  • To send print jobs to your printer, you will need Raster Image Processor (RIP) software, which should be run on a separate computer. RIP software is available from various different companies; it is not provided with the printer.
Connectivity
Interfaces (standard)
Gigabit Ethernet (1000Base-T)
Printer Weight and Dimensions
Dimensions (w x d x h): Printer 2465 x 690 x 1370 mm (97 x 27.5 x 54 in)
Dimensions (w x d x h): Shipping 2690 x 815 x 1200 mm (105.9 x 32.1 x 47.2 in)
Weight: Printer 202 kg (445 lb)
Weight: Shipping 291 kg (642 lb)
