    Fix Windows 10 Update Issues
HP Business Notebooks - How to Replicate BIOS Settings on HP Business Notebooks
This document describes how to replicate BIOS settings on HP Business notebooks.
Details
The HP System Software Manager (SSM) is a utility that automatically detects and updates BIOS, device drivers, and management agent versions on the networked PCs.
The latest version of the software can be downloaded from the link below:
SSM includes software called BiosConfigUtiliy.exe which can be used to change BIOS settings.
First, download and install SSM on all of the computers on which you want to replicate the BIOS. Than, on the notebook you want to replicate the BIOS settings from run BiosConfigUtility.exe with the /getconfig:filename.txt parameter.
This will export a text file with the current BIOS settings. Open the text file in a notepad application to view the content.
Active BIOS options are marked with a *. To make changes move the * from one option to the next.
Make any changes to the settings that are required, then save and exit.
Run BiosConfigUtility.exe from a DOS prompt with the /setconfig:filename.txt parameter to apply the changed settings.
For complete information and options on the BiosConfigUtility please run BiosConfigUtility.exe with the /? parameter.
For more information and options please refer to the SSM User Manual available from the HP SSM site:
