HP ZR2240w 21.5-inch LED Backlit IPS Monitor - Overview
Product description
The HP ZR2240w 54.6-cm (21.5-inch) LED Backlit IPS Monitor has a new LED backlight, HDMI input and 1920 x 1080 full HD1 resolution in an ultra-modern design that is sleeker than ever to perfectly complement HP Z Workstations.
Product features
Feature
Type
IPS (In-Plane Switching) LED Backlit LCD
Viewable Image Area (diagonal)
54.52 cm (21.5 in) widescreen; diagonally measured
Optimal resolution
1920 x 1080 (Full HD) @ 60 Hz
Viewing angle (typical)
Up to 178° horizontal/178° vertical (10:1 minimum contrast ratio)
User programmable modes
Yes (20)
Anti-glare
Yes
Plug and play
Yes
Tilt range
-5° to +35°
Swivel range
Yes (+/- 45°)
Height adjustable
Yes (9 cm)
Response time (typical)1
8 ms (gray to gray)
Pivot rotation
Yes
1. All performance specifications represent the typical specifications provided by HP's component manufacturers; actual performance may vary either higher or lower.
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
