    Looking for Site Help?
Removing and Replacing the Rear Cover in HP TouchSmart 320-1000 Series Desktop PCs
This document applies to HP Touch 320-1000 and 320-1100 desktop computers.
HP Touch 320-1x00 desktop computer
Before you begin
  • You need a Phillips head screwdriver.
  • Remove all CDs and DVDs from the optical drive.
  • Turn off the computer, and disconnect all cables. Be sure to disconnect the network cable before disconnecting the power cord.
  • Place the computer face-down on a soft flat surface. HP recommends that you place the computer on a blanket, towel, or other soft cloth to protect the touch screen surface from scratches or other damage.
  • Do not remove a component from the protective packaging until you are ready to install it.
  warning:
Video overview
For best quality on dial-up connections, wait until the video has fully loaded before viewing.
Removing and replacing the rear cover
Remove the rear cover to access the internal components.
Removing the rear cover
Use the following steps to remove the rear cover.
Step 1
Place the computer face down on a table with the stand overhanging the table edge.
The computer on a table
Step 2
Loosen each of the two captive Phillips head screws for the rear cover until you hear the screw make a clicking sound five times.
Loosen the screws
Step 3
Pry up on the bottom edges of the rear cover then work the rest of the cover free from the computer.
Replacing the rear cover
Use the following steps to replace the rear cover:
Step 1
Find the small tabs on the outer edge of the rear cover.
Finding the tabs
Step 2
Find the outer lip of the front bezel.
Outer lip of the front bezel
Step 3
Align the rear cover onto the back of the computer...
Replacing the cover
...making sure the cover is correctly placed over the side I/O ports.
Side I/O ports
Step 4
Press down firmly until the cover snaps into place.
The bottom edge will not yet be flush against the front bezel.
Pressing down to snap the cover into place
Step 5
Tighten the two captured screws on the rear cover until the bottom edges of the rear cover are flush against the edge of the outer ring of the bezel.
Tightening the screws
Country: Flag Bulgaria
