HP ProBook 4535s Notebook PC - Removing and Replacing the Service Door
This document is provided to assist in removing and replacing the service door for the HP ProBook 4535s Notebook PC.
Minimum skill level
The end user requires no hardware-specific training to replace the defective part. The end user should have familiarity with system hardware and software requiring repair.
Parts required
The replacement part number will vary depending on the service door that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Bottom door
646263-001 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the service door, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to Service Media Library), then select Service door from the menu on the upper left hand side of the screen.
Click here to view the service door removal video (right-click on the link to open in a new window/tab).
Service door removal
Observe all precautions when removing and replacing components.
  2. Slide the battery release latches towards the battery icons until the service door disengages from the base enclosure.
  3. Lift the service door and remove it.
Service door replacement
  1. Place the service door on the base enclosure.
  2. Slide the service door towards the rear of the notebook until it clicks into place.
Country: Flag Bulgaria
