HP Compaq 8200 Elite All-in-One Business PC - Removal and Replacement Procedures All-in One (AIO) Chassis
The following sections provide information about disassembling various components of the computer.
Preparing to Disassemble the Computer
To avoid injury and equipment damage, always complete the following steps in order, when opening the HP Pro All-in-One.
  1. Remove all media (CD, DVD, etc.) from the computer.
  2. Shut down the computer.
  3. After the system has completely shut down, disconnect the power adapter from the back of the computer.
  4. Disconnect all other attached cables from the back of the computer.
  5. Place the computer face down on a soft flat surface. HP recommends that you set down a blanket, towel, or other soft cloth to protect the screen surface from scratches or other damage.
  warning:
Beware of sharp edges inside the chassis.
Synchronizing the Optional Wireless Keyboard or Mouse
The optional wireless keyboard and mouse are easy to set up. Just remove the battery tabs on both the keyboard and the mouse. Also, make sure the Power switch on the bottom of the mouse is in the On position (the keyboard does not have a Power switch). Then, turn on the computer. If you have trouble using the keyboard and mouse, manually synchronize them as described below.
For better mouse battery life and performance, avoid using your mouse on a dark or high-gloss surface, and turn mouse power off when not in use.
The wireless keyboard and mouse are pre-synchronized to work with your computer. The keyboard and mouse should work immediately after you first pull the battery tabs to activate the preinstalled batteries, and then turn on the mouse.
You may need to manually synchronize the wireless keyboard or mouse if they are not functioning. To synchronize them:
  1. Make sure the keyboard and mouse are next to the computer, within 30 cm (1 foot) and away from interference from other devices.
  2. Turn on the computer.
  3. Insert the wireless receiver into a USB port on the computer.
    Figure :
  4. Make sure the Power switch on the bottom of the mouse is in the On position (1).
  5. Press the Connect button on the bottom of the mouse (2) for five seconds. The blue activity LED from the wireless receiver illuminates when the synchronization command has been received and turns off when synchronization is complete.
  6. Press the Connect button on the bottom of the keyboard (3) for five seconds. The blue activity LED from the wireless receiver illuminates when the synchronization command has been received and turns off when synchronization is complete.
    Figure :
If the procedure does not work, remove and then re-insert the wireless keyboard and mouse receiver from the back of the computer and then synchronize the keyboard and mouse again.
Center Access Panel
The center access panel is located above the stand. You must remove it to remove the drive cover and memory cover.
Center access panel location
Figure :
To remove the center access panel:
  1. Prepare the computer for disassembly (see Preparing to Disassemble the Computer).
  2. Pull outward on the panel at the slot on the top edge of the panel.
    Figure :
To replace the center access panel, reverse the removal procedures.
Stand
The stand is secured with three Torx screws. You must remove the center access panel to remove the stand.
To remove the stand:
  2. Remove the center access panel (see Center Access Panel).
  3. Remove the three silver Torx screws (1) that secure the stand to the computer.
  4. Rotate the stand upward (2), and then lift the stand off the computer (3).
    Figure :
To replace the stand, reverse the removal procedures.
Memory Access Panel
The memory access panel is located on the rear, right side of the computer (viewed from behind). You must remove it to access the memory modules and to remove the main rear cover.
Memory access panel location
Figure :
To remove the memory access panel:
  3. Pull upward on the two tabs on the inside edge of the panel (1) and slide the panel off the computer (2).
    Figure :
To replace the memory access panel, reverse the removal procedures.
Drive Access Panel
The drive access panel is located on the rear, left side of the computer (viewed from behind). You must remove it to access the hard drive and optical drive and to remove the main rear cover.
Drive access panel location
Figure :
To remove the drive access panel:
  3. Push downward on the two tabs on the inside edge of the panel (1) and slide the panel off the computer (2).
    Figure :
To replace the drive access panel, reverse the removal procedures.
Optical Drive
The optical drive is located under the drive access panel on the left side of the computer (viewed from behind). It is secured with one Torx screw.
Optical drive location
Figure :
To remove the optical drive:
  3. Remove the drive access panel (see Drive Access Panel).
  4. Remove the black Torx screw (1) that secures the drive to the computer.
  5. Insert a flat-bladed screwdriver or finger to push the bracket on the rear side of the optical drive(2) to disengage the drive from the connector, and then slide the drive out of the computer (3).
    Figure :
  6. If you need to remove the drive bracket from the drive, remove the two screws (1) that secure the bracket to the drive, and then remove the bracket from the drive (2).
    Optical drive spare part kits do not include replacement brackets. Reuse the existing bracket.
    Figure :
To install an optical drive, reverse the removal procedures.
Hard Drive
The hard drive is located under the drive access panel on the left side of the computer (viewed from behind). The drive is secured with one captive Torx screw and is housed in a removable cage.
Hard drive location
Figure :
  4. Loosen the captive Torx screw next to the front of the drive that secures the drive to the computer. You can use either a Torx or slotted screwdriver to loosen the screw.
    Figure :
  5. Grasp the handle on top of the hard drive cage (1) and slide the cage toward the outer edge of the computer, then lift the cage out of the computer (2).
    Figure :
  6. Remove the four mounting screws that secure the drive to the cage. Do not remove the blue rubber grommets behind each screw. They must stay attached to the cage when installing a new hard drive.
    Inspect the four blue rubber grommets in case some of them are damaged or lost. Grommet spare parts are available.
    Figure :
  7. Slide the hard drive out of the cage.
    Figure :
To replace the hard drive, reverse the removal procedures.
Memory
Memory modules are located on the right side of the computer (viewed from behind) under the memory cover. The computer has two memory slots.
Memory module location
Figure :
The computer comes with double data rate 3 synchronous dynamic random access memory (DDR3-SDRAM) small outline dual inline memory modules (SODIMMs).
The memory sockets on the system board can be populated with up to two industry-standard SODIMMs. These memory sockets are populated with at least one preinstalled SODIMM. To achieve the maximum memory support, you can populate the system board with up to 8 GB of memory.
For proper system operation, the SODIMMs must be:
  • industry-standard 204-pin
  • unbuffered non-ECC PC3-10600 DDR3-1333 MHz-compliant
  • 1.5 volt DDR3-SDRAM SODIMMs
The DDR3-SDRAM SODIMMs must also:
  • support CAS latency 9 DDR3 1333 MHz (9-9-9 timing)
  • contain the mandatory Joint Electronic Device Engineering Council (JEDEC) specification
In addition, the computer supports:
  • 512-Mbit, 1-Gbit, and 2-Gbit non-ECC memory technologies
  • single-sided and double-sided SODIMMS
  • SODIMMs constructed with x8 and x16 devices; SODIMMs constructed with x4 SDRAM are not supported
The system will not operate properly if you install unsupported SODIMMs.
There are two memory sockets on the system board located behind the memory access panel. To remove or install memory modules:
To remove a memory module:
  3. Remove the memory access panel (see Memory Access Panel).
  4. Pull upward on the two raised tabs on the memory cover and lift the cover off the rear panel.
    Figure :
  5. To remove a memory module, press outward on the two latches on each side of the SODIMM (1) then pull the SODIMM out of the socket (2).
    Figure :
  6. To install a memory module, slide the SODIMM into the socket at approximately a 30° angle (1) then press the SODIMM down (2) so that the latches lock it in place.
    Figure :
    A memory module can be installed in only one way. Match the notch on the module with the tab on the memory socket.
The computer automatically recognizes the additional memory when you turn on the computer.
Top Panel
The top panel is secured with two Torx screws. Removing it allows access to the webcam and allows you to remove the main rear cover.
Top panel location
Figure :
To remove the top panel:
  4. Remove the drive access panel (see Drive Access Panel).
  5. From the top of the computer, remove the two black Torx screws (1) that secure the top panel to the computer.
  6. Rotate the top of the panel outward (2), and then lift the panel off the computer.
    Figure :
To replace the top panel, reverse the removal procedures.
Webcam Module
The webcam module is located at the top of the computer beneath the top panel. It is secured with two silver Phillips screws and has one connector.
Webcam module location
Figure :
To remove the webcam module:
  5. Remove the top panel (see Top Panel).
  6. Remove the two silver Phillips screws (1) that secure the webcam module to the computer.
  7. Lift the webcam module as much as the cable allows, and then disconnect the cable from the module (2).
  8. Remove the webcam from the computer (3).
    Figure :
To install a webcam module, reverse the removal procedures.
Rear Cover
The rear cover is secured with six Torx screws. You must pry it off at the seams around the edges of the computer.
To remove the rear cover:
  5. Remove the stand (see Stand).
  6. Remove the optical drive (see Optical Drive).
  7. Remove the top panel (see Top Panel).
  8. Remove the six black Torx screws that secure the panel to the computer (1).
  9. Working from left to right, pry the cover off the computer by pulling the edges (2) of the cover up and away from the computer.
    Figure :
  10. Remove the rear cover from the computer.
To replace the rear cover, reverse the removal procedures.
System Board Cover
The system board cover protects the system board. It is secured with six Torx screws.
System board cover location
Figure :
To remove the system board cover:
  8. Remove the rear cover (see Rear Cover).
  9. Remove the six black Torx screws that secure the cover to the computer.
    Figure :
  10. Lift the cover from the computer.
    Figure :
To install the system board cover, reverse the removal procedures.
Sidekey Board
The sidekey board is located on the bottom left side of the computer (viewed from behind). It is secured with two Torx screws and has one connector.
The associated cable connects to the front power switch assembly. To remove it, you must remove the stand bracket, disassembly of which is shown later in this document at Stand Bracket.
Sidekey board location
Figure :
To remove the sidekey board:
  9. If replacing the cable, remove the system board cover (see System Board Cover).
  10. Disconnect the cable from the sidekey board (1).
    Be careful not to damage the cable when disconnecting it from the board. Do not pull on the wires.
  11. Remove the two silver Torx screws (2) that secure the board to the computer.
  12. Rotate the bottom of the board upward (3), and then remove the board from the computer.
    Figure :
  13. If you need to remove the cable:
    1. Remove the stand bracket by removing the four black Torx screws that secure it to the computer (1), and then lifting the bracket from the computer (2).
      Figure :
    2. Disconnect the cable from the PB/LED connector on the system board. The following image shows the cable highlighted by arrows.
    3. The cable includes the power switch assembly (shown by callout (1) in the following image). The cable routes beneath the stand bracket (not shown in the following image) to the PB/LED system board connector (shown by callout (2) in the following image).
      Figure :
    4. Lift the power switch assembly up and off the front bezel.
      Figure :
    5. Lift the cable out of the computer.
To install the sidekey board or cable, reverse the removal procedures.
Converter Board
The converter board is located on the left side of the computer. It is secured with two Torx screws and has two connectors.
Converter board location
Figure :
To remove the converter board:
  9. Disconnect the two cables from the board (1).
    Be careful not to damage the cables when disconnecting them from the board. Do not pull on the wires.
  10. Remove the two silver Torx screws (2) that secure the board to the computer.
  11. Lift the converter board from the computer (3).
    Figure :
    Be sure to correctly position the jumpers on the converter board for the installed display panel, as follows:
    Incorrect jumper placement can result in damage to the converter board.
    • LG panel: pins 8 & 7
    • Samsung panel: pins 6 & 5
To install the converter board, reverse the removal procedures.
Speakers
The speakers are located at the bottom of the computer. Two separate speakers are each secured by two Torx screws and have separate cables and system board connectors.
Speaker location
Figure :
To remove the speakers:
  9. Remove the system board cover (see System Board Cover).
  10. Remove two Torx screws (1) that secure each speaker to the computer.
  11. Disconnect the speaker cables from the system board connectors (2). The left speaker connects to the white connector labeled SPKR_L. The right speaker connects to the black connector labeled SPKR_R.
  12. Remove the speakers from the computer (3).
    Figure :
To install the speakers, reverse the removal procedures.
WLAN Module
The WLAN module is located on the right side of the system board. The module is secured with two Phillips screws and has two connected antennas.
WLAN module location
Figure :
To remove the WLAN module:
  10. Disconnect the antenna cables from the module (1).
  11. Remove the two Phillips screws (2) that secure the module to the computer.
  12. Lift the module to a 45-degree angle (3), and then pull it away to remove it from the socket.
    Figure :
To install the WLAN module, reverse the removal procedures.
WLAN modules are designed with a notch to prevent incorrect insertion.
The following image shows the WLAN antenna routing paths.
Antenna routing paths
Figure :
Heat Sink (Thermal Module)
The heat sink is secured with six Torx screws. You do not have to remove the fans to remove the heat sink.
Heat sink location
Figure :
To remove the heat sink:
  10. Loosen the four silver captive Torx screws in the order indicated on the heat sink (1) - (4).
  11. Remove the two black Torx screws from the top of the heat sink (5).
  12. Lift the heat sink from the computer (6).
    To reduce a degradation in thermal performance, be sure not to touch the thermal grease on the surface of the processor or the heat sink.
    Figure :
To replace the heat sink, reverse the removal procedures.
Processor
  10. Remove the heat sink (see Heat Sink (Thermal Module)).
  11. Rotate the locking lever to its full open position (1).
  12. Raise and rotate the microprocessor retainer to its fully open position (2).
  13. Carefully lift the processor from the socket (3).
    Do NOT handle the pins in the processor socket. These pins are very fragile and handling them could cause irreparable damage. Once pins are damaged it may be necessary to replace the system board.
    The heat sink must be installed within 24 hours of installing the processor to prevent damage to the processor’s solder connections.
    Figure :
To install a new processor:
  1. Place the processor in its socket and close the retainer. Make sure the slot in the processor fits into the post on the socket.
  2. Secure the locking lever. If reusing the existing heat sink, go to step 3. If using a new heat sink, go to step 6.
  3. If reusing the existing fan sink, clean the bottom of the fan sink with the alcohol pad provided in the spares kit.
    Before reinstalling the fan sink you must clean the top of the processor and the bottom of the fan sink with an alcohol pad supplied in the spares kit. After the alcohol has evaporated, apply thermal grease to the top of the processor from the syringe supplied in the spares kit.
  4. Apply the thermal grease provided in the spares kit to the top of the processor and install the fan sink atop the processor.
  5. Go to step 7.
  6. If using a new fan sink, remove the protective covering from the bottom of the fan sink and place it in position atop the processor.
  7. Secure the fan sink to the system board and system board tray.
    Fan sink retaining screws should be tightened in diagonally opposite pairs (as in an X) to evenly seat the fan sink on the processor. This is especially important as the pins on the socket are very fragile and any damage to them may require replacing the system board.
After installing a new processor onto the system board, always update the system ROM to ensure that the latest version of the BIOS is being used on the computer. The latest system BIOS can be found on the Web at the HP Software and Drivers page.
Fan Assembly
The fan assembly consists of two fans located near the top of the computer below the heat sink. The assembly is secured with four Torx screws (two per fan) and connects to the system board using two separate connectors. You do not have to remove the heat sink to remove the fans.
Fan assembly location
Figure :
To remove the fan assembly:
  10. Remove the four silver Torx screws (1) that secure the fan assembly to the computer.
  11. Disconnect the fan cables (2) from the system board connectors labeled CHFAN and CPUFAN.
  12. Lift the fan assembly from the computer (3).
    Figure :
To install the fan assembly, reverse the removal procedures.
Display Cable
The main display cable is located just above the system board. The heat sink covers the connector on the display panel.
Display cable location
Figure :
To remove the display cable:
  10. Remove the heat sink (see Heat Sink (Thermal Module).
  11. Disconnect the cable from the LVDS1 connector on the system board (1).
  12. Disconnect the cable from the display panel by pressing in the latches on the side of the cable (2) and pulling it from the connector (3).
    Figure :
  13. Remove the display cable from the computer.
To install the display cable, reverse the removal procedures.
System Board
The system board is located on the right side of the computer (viewed from the rear) under the system board cover. It is secured with seven Torx screws.
System board location
Figure :
To remove the system board:
  4. Remove the memory module (see Memory).
  5. Remove the drive access panel (see Drive Access Panel).
  6. Remove the stand (see Stand).
  7. Remove the optical drive (see Optical Drive).
  8. Remove the top panel (see Top Panel).
  9. Remove the rear cover (see Rear Cover).
  10. Remove the system board cover (see System Board Cover).
  11. Remove the WLAN module (see WLAN Module).
  12. Remove the heat sink (see Heat Sink (Thermal Module).
  13. Remove the processor (see Processor).
  14. Disconnect all cables from the system board, noting their location for reinstallation.
  15. Remove the seven silver Torx screws (circled in image) that secure the system board to the computer.
    Figure :
  16. Lift the system board straight up and out of the computer.
Before returning the defective system board, remove the CPU cover from the replacement system board and install it on the defective system board.
To install the system board, reverse the removal procedures.
Updating SMBIOS Information
When replacing the system board, you must reprogram the SMBIOS information on the affected computer. Failure to reprogram the board will result in eventual failure, such as an activation failure (need to reactivate the system) or a system recovery failure.
To update SMBIOS information in Computer Setup:
  1. Turn on or restart the computer.
  2. Press Esc while the “Press the ESC key for Startup Menu” message is displayed at the bottom of the screen.
    If you do not press Esc at the appropriate time, you must restart the computer and again press Esc when the monitor light turns green to access the utility.
  3. Press F10 to enter Computer Setup.
  4. Go to Security > System ID’s.
  5. If necessary, press Ctrl+A to initiate edit mode.
  6. Edit the fields listed. If the feature byte has data or is not editable, then it was not cleared and cannot be edited.
System ID Setup Page
Setup Field Name
Comment
Label
Product Name
Enter the Model name/number or marketing name.
Flexbuild
Serial Number
Enter the Serial Number of Unit.
Support
SKU Number
Enter the SKU or Product Number including Localization Code.
Support
Feature Byte
Enter the Feature Byte string. The feature byte string is case dependent.
The label includes spaces after every four characters. You can enter or ignore these spaces – their only purpose is to help with data entry. There is a character limitation of 40 bytes per line. When you reach this limit, go to the next line to continue data entry. BIOS ignores the spaces and lines.
If you make an error during data entry, the data will not validate, and the computer asks you to correct your data input.
Flexbuild
Build ID
The Build ID of the unit.
Flexbuild
Flexbuild Support Label
Use the following labels to locate the Build ID, Feature Byte, and Product Name.
Support Label
Use the following labels to locate the Serial Number and Product Number.
Stand Bracket
The stand bracket is located near the middle of the computer, below the fans. Remove the bracket to gain access to the drive cables and sidekey board cable assembly. The bracket is secured with four Torx screws.
Stand bracket location
Figure :
To remove the stand bracket:
  10. Remove the four black Torx screws (1) that secure the stand bracket to the computer.
  11. Lift the bracket from the computer (2).
    Figure :
To install the stand bracket, reverse the removal procedures.
Hard Drive and Optical Drive Cables and Connectors
The hard drive and optical drive connectors are located near the middle of the computer, below the fans, and under the bracket that secures the stand. Each connector is secured with two Torx screws and has two cables that connect to the system board.
The optical drive connector (1) is positioned above the hard drive connector (2). The optical drive connector cables are longer than the hard drive connector cables.
Hard drive cable and optical drive cable location
Figure :
To remove the hard drive or optical drive connector:
  6. Remove the hard drive (see Hard Drive).
  11. Remove the stand bracket (see Stand Bracket).
  12. Remove two silver Torx screws that secure the hard drive connector (1) or the optical drive connector (2) to the computer.
  13. Remove the cables from the metal clips (3) built into the computer.
  14. Disconnect the hard drive cables (4) or the optical drive cables (5) from the system board.
  15. Remove the connector from the computer.
    Figure :
To install the hard drive or optical drive connector, reverse the removal procedures.
Front Bezel
The front bezel is located on the front of the computer and is secured to the main system bracket with eight Torx screws and eight tabs. You must remove the main system bracket from the bezel to gain access to the bezel and to the display panel. The display panel sits between the main bracket and the front bezel.
You can remove the front bezel without disassembling many of the computer's components. Most components can remain attached to the display panel bracket. The following procedure demonstrates removing the bezel while removing the smallest number of components possible.
To remove the front bezel:
  11. Disconnect the speaker cables from the system board.
  12. Disconnect the backlight cable from the converter board.
  13. Disconnect the display cable from the system board.
  14. Remove the power switch assembly cable from the front bezel. You do not have to remove the remaining cables.
  15. Remove the eight black Torx screws (1) that secure the bezel to the main system bracket assembly.
  16. Lift the eight tabs (2) that secure the bezel to the main system bracket assembly. Be sure to slide the bracket free from the tabs as you lift each one.
  17. Lift the main system bracket assembly off the front bezel (3).
    The display panel sits between the main bracket assembly and the front bezel.
    Figure :
  18. Lift the display panel from the front bezel by pressing the four tabs (two on each side) to release the panel from the bezel, and then lifting the panel off the bezel.
    Figure :
To install the front bezel, reverse the removal procedures.
Display Panel
Two different display panels are available, LG and Samsung.
To ensure compatibility, when replacing the display panel, remove the backlight cable with the old panel and replace with the new cable supplied in the replacement kit.
The display panel is secured to the display bracket with four Torx screws, as follows:
  • LG - two screws on top, two screws on the bottom
  • Samsung - two screws on each side
To remove the display panel:
  11. Remove the power switch assembly cable. You do not have to remove the remaining cables.
  12. Remove the front bezel (see Front Bezel).
  13. Disconnect the display cable (1) and the backlight cable (2) from the display panel.
    Figure :
  14. Remove the four silver Torx screws that secure the display panel to the frame or brackets.
    The LG panel mounts to a large frame using four screws - two on top, two on the bottom.
    The Samsung panel mounts to two small brackets, one on each side. Each bracket is secured by two screws.
  15. If removing the LG panel, lift the display panel from the frame.
    If removing the Samsung panel, remove the brackets from the display panel.
    Figure :
    Figure :
  16. Be sure to correctly position the jumpers on the converter board for the installed display panel, as follows:
To install a display panel, reverse the removal procedures.
The following images show how the brackets should be installed on Samsung panels. Each bracket is secured to the side of the panel with two Torx screws.
Samsung panel bracket locations
Figure :
Samsung panel bracket – left side
Figure :
Samsung panel brackets – right side
Figure :
