HP SignagePlayer mp8200 and mp8200s - Specifications
Physical specifications
Specification
Dimensions (H x W x D)
Chassis (without stand):
  • 66 x 252 x 254 mm (2.6 x 9.9 x 10 in)
Tower stand:
  • 27 x 125 x 170 mm (1.1 x 4.9 x 6.7 in)
Packaging:
  • 218 x 398 x 500 mm (8.6 x 15.7 x 19.7 in)
System weight
3.1 kg (6.8 lb)
Shipping weight
6.5 kg (14.4 lb)
Max supported weight (desktop orientation)
35.0 kg (77.0 lb)
Electrical specifications
Specification
Operating voltage range
90 - 264 V ac
Rated voltage range
100 - 240 V ac
Rated line frequency
50 or 60 Hz
Operating line frequency range
47 or 63 Hz
Current leakage (NFPA 99)
<250 µA
Total cord length
8 in (12 ft)
Rated input current with energy efficient power supply
  • 135 W: 2.4 A
  • 180 W: 2.9 A
Environmental specifications
Specification
Operating temperature1
10° to 35°C (50° to 95°F)
Non-operating temperature
-30° to 60°C (-22° to 140°F)
Operating humidity
10% to 90% non-condensing at ambient
Non-operating humidity
5% to 95% non-condensing at ambient
Operating altitude
3048 m (10,000 ft)
Non-operating altitude
9144 m (30,000 ft)
1: Operating temperature is de-rated 1.0°C per 300 m (1000 ft) to 3000 m (10,000 ft) above sea level, no direct sustained sunlight. Maximum rate of change is 10°C/hr. The upper limit may be limited by the type and number of options installed.
