HP SignagePlayer mp8200 and mp8200s - Overview
Product description
The HP SignagePlayer mp8200 Series supports the second generation Intel Core processor family. Based on a new PC micro-architecture, the processor is designed for a two-chip platform consisting of a processor and Platform Controller Hub (PCH).
Product features
Feature
Intel Q67 Express
Processor
  • Intel Core i3-2100 Processor, 3.10 GHz, 3M cache
  • Intel Core i5-2400S Processor, 2.50 GHz, 6M cache
Hard disk drives
160GB 7,200 rpm, 3.0 Gb/s, 2.5 inch
System memory
1GB and 2GB DDR3 DRAM technologies are supported
Towerable orientation
Product can be oriented as either a desktop or a tower
Drive lock
Implementation of the industry standard ATA Security feature set. When enabled, it prevents software access to user data on the drive until one or two user-defined passwords are provided.
Graphics
  • Intel HD Graphics 2000/3000 (integrated)
  • HP DisplayPort to DVI-D adapter
  • HP DisplayPort to VGA adapter
  • HP DisplayPort to HDMI adapter
Audio/Visual
  • High Definition Audio with Realtek ALC261 codec (all ports are stereo)
  • Microphone/Headphone and dedicated headphone front ports
  • Line-out and Line-In rear Ports
  • Multi-streaming capable
  • Internal speaker (standard)
Network interface connections1
  • Intel 82579LM integrated GbE network connection
  • Intel Centrino Advanced-N 6205 Wireless NIC (mini PCI Express)
Input devices
HP USB Standard keyboard
1: Either the integrated network connection or the Intel Centrino wireless NIC is required to support Intel vPro Technology features on the mp8200 model.
Software overview
Feature
  • Genuine Windows Embedded Standard 20091
  • Genuine Windows Embedded Standard 72
Value added software (included on mp8200s)
Scala player
1: mp8200s model
2: mp8200 model
Links to product QuickSpecs
Direct links to the QuickSpecs will be added as soon as they become available.
