HP ZR2040w 20-inch LED Backlit IPS Monitor - Overview
Product description
The HP ZR2040w monitor is designed to be a workhorse display companion for HP Z Workstation with mission critical reliability that’s energy efficient and affordable. This 20-inch diagonal monitor as an LED backlit IPS monitor with 16:9 aspect ratio that’s also ultra-modern and super sleek to perfectly complement HP Z Workstations.
Product features
Feature
Type
IPS (in-plane switching) LED Backlit LCD
50.8 cm (20 in) widescreen
Screen opening (W x H)
44.28 x 24.91 cm (17.43 x 9.81 in)
Aspect ratio
16:9
Optimal resolution
1600 x 900 @ 60 Hz
Viewing angle (typical)
  • Horizontal viewing angle: 178°
  • Vertical viewing angle: 178°
Brightness (typical)1
250 nits (cd/m2)
Contrast ratio (typical)1
1000:1
Dynamic contrast ratio (typical)1
N/A
Response time (typical)1
7 ms (GtG)
Pixel pitch
0.276 mm
Backlight lamp life (to half brightness)
30,000 hours
Color gamut (typical)
72%
Color support
Can display up to 16.7 million colors with the use of FRC technology
1: All performance specifications represent the typical specifications provided by HP's component manufacturers; actual performance may vary either higher or lower.
Links to product QuickSpecs
Direct links to the QuickSpecs will be added as soon as they become available.
