HP rp5800 Retail System - Removing and Replacing the Primary Hard Drive
This document is provided to assist in removing and replacing the primary hard drive for the HP rp5800 Retail System.
Minimum skill level
Parts required
The replacement part number will vary depending on the primary hard drive that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
1TB SATA III 6-Gb/s transfer speed hard drive - 7,200 rpm
636930-001 (Modified)
Yes
500GB SATA III 6-Gb/s transfer speed hard drive - 7,200 rpm - With Native Command Queuing (NCQ) and Smart IV technology
636929-001 (Modified)
Yes
250GB SATA 6-Gb/s hard drive - 7,200 rpm - With Native Command Queuing (NCQ) and Smart IV technology
636927-001 (Modified)
Yes
160GB SATA interface SSD (Solid State Disk) drive - With 3.5-inch bay adapter bracket and screws
646809-001 (Modified)
Yes
80GB SATA interface SSD (Solid State Disk) drive - Intel branded, 2.5-inch form factor
607817-001 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the primary hard drive, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to Service Media Library), then select Primary hard drive from the menu on the upper left hand side of the screen.
Click here to view the primary hard drive removal video (right-click on the link to open in a new window/tab).
Primary hard drive removal
  2. Rotate the drive cage to the up position.
  3. Rotate the power supply to the up position.
  4. Disconnect the data and power cables from the back of the drive.
  5. While pressing on the drive release latch, slide the drive toward the front of the computer until it stops.
  6. Lift the drive up and out of the drive bay.
If the replacement drive does not include guide screws, remove and reuse the screws from this drive.
Primary hard drive replacement
  1. Align the guide screws on the drive with the J-slots in the drive bay and push the drive down into the drive bay.
  2. Slide the drive toward the back of the computer until it locks into place.
  3. Connect the power and data cables to the drive.
  4. Rotate the power supply to the down position.
  5. Rotate the drive cage to the down position.
Parts return
