HP Pro 3300 Small Form Factor PC - Removing and Replacing the Power Supply
This document is provided to assist in removing and replacing the power supply for the HP Pro 3300 Small Form Factor PC.
Minimum skill level
The End-User should possess product-specific knowledge and technical skill on how to service the system, and have familiarity with the operating system.
Parts required
The replacement part number will vary depending on the power supply that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Power supply, 220 W
656722-001 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the power supply, click on the link below. Or use the product video listing on the HP Services Media Library, (Click here to go to HP Service Media Library), then select Power supply from the menu on the upper left hand side of the screen.
Click here to view the power supply removal video (right-click on the link to open in a new window/tab).
Power supply removal
  2. Swing the optical drive cage up partially.
  3. Detach the power supply connector to the hard drive.
  4. Detach the power supply connector to the optical drive.
  5. Detach the power supply connectors to the motherboard.
  6. Clip any cable ties securing the power cables to other system connectors.
  7. Free the power supply connectors from the large cable guide on the bottom of the PC.
  8. Remove the four screws on the rear of the PC that secure the power supply to the unit.
  9. Press down on the power supply latch inside the PC, slide the power supply back into the unit, and pull the it entirely out of the PC.
Power supply replacement
  1. There is a slot on the side of the power supply, that fits onto a tab on the side of the PC.
  2. To replace the power supply, align the power supply against the bottom of the PC. Slide the power supply towards the rear of the PC until the power supply is secure.
  3. Reattach the four screws at the rear of the system.
  4. Connect the two power supply connectors to the motherboard and the power connectors to the optical and hard drives.
  5. Secure the power supply connector to the fan connector with cable ties.
  6. Swing the optical drive bay back into place.
Parts return
