When you attempt to connect wirelessly to a network with WEP encryption and Shared Key Authentication, the product fails to connect. A wireless test report might incorrectly indicate that the connection failed due to MAC filtering.
- ${title}
- ${title}
- ${title}
- ${title}
HP ENVY 110 e-All-in-One Printer Series (D411) - Unable to Connect to a Wireless Network When Using WEP Encryption and Shared Key Authentication
Issue
Solution
Follow these steps in the order presented to resolve the issue.
Step one: Open your router's configuration utility
Select one of the following methods, and then follow the steps to open your router's configuration utility.
Step two: Configure your network settings
The following steps might vary depending on your router’s manufacturer. Use the following steps as a guide to configure your network settings.
note:HP recommends that you secure your network with WPA or WPA2 wireless security, if your router and network devices support it.
Locate the wireless configuration settings using the router’s configuration utility.
Locate the router’s Authentication Type settings, and then change the Authentication type to Auto or Open.
Click Save, and then close the configuration utility.
Step three: Restore your product's network default settings
Follow these steps to restore your product's network default settings.
From the home screen on the product control panel, touch the Wireless icon (
Touch Settings. A list of wireless options displays.
Touch Restore Network Defaults.
Touch Yes to confirm your selection.
Step four: Connect to the wireless network
Follow these steps to connect your product to the wireless network.
Touch Wireless Setup Wizard. The Wireless Setup Wizard searches for networks, and then displays them in a list.
Touch and then slide your finger up or down on the display until you locate your network name (SSID) in the list, and then touch your SSID to select it.If the list of available networks does not include your network, follow these steps to add it manually.
Touch and then slide your finger up or down on the display, and then select Enter New Network Name (SSID). A touch keypad displays.
Enter your network name using the touch keypad, and then touch Done.
Make sure that you enter the exact uppercase (capital) and lowercase (small) letters. Otherwise, the wireless connection fails. -
The product searches for, and then displays, the network. Touch OK to confirm.The Security menu displays.
On the Security menu, touch Yes, my network uses WEP encryption or Yes, my network uses WPA encryption, based on your network setup.If you are not using encryption, touch No, my network does not use encryption.
If prompted, use the touch keypad to enter the WEP or WPA key, and then touch Done.
Touch OK to confirm the network settings.
Wait for the product to connect to the wireless network. A message displays on the control panel when the product has successfully connected the network.
If a connection error message displays, make sure that the network name and security key are correct, and then follow the prompts to enter the information again. -
When the product successfully connects to the wireless network, touch OK to continue, or touch Print to print a Wireless Network Test Report.
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Bulgaria
- ${title}
hp-hero-support-search
- ${title}
