HP EliteBook 2560p Notebook PC - Removing and Replacing the Hard Disk Drive
This document is provided to assist in removing and replacing the hard disk drive for the HP EliteBook 2560p Notebook PC.
Minimum skill level
The end user requires no hardware-specific training to replace the defective part. The end user should have familiarity with system hardware and software requiring repair.
Parts required
The replacement part number will vary depending on the hard disk drive that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
750GB SATA hard disk drive - 7200 rpm, 2.5-inch form factor
633252-001 (Original)
Yes
500GB SATA hard disk drive - 7200 rpm
634925-001 (Modified)
Yes
320GB SATA hard disk drive - 7200 rpm
641672-001 (Modified)
Yes
320GB SATA hard disk drive - 7200 rpm, 2.5-inch form factor, 9.5-mm height (raw drive)
626978-001 (Modified)
Yes
250GB SATA hard drive - 7200 rpm, 2.5-inch form factor, 9.5-mm height
635225-001 (Modified)
Yes
160GB solid-state drive
651389-001 (Modified)
Yes
128GB solid-state drive
651388-001 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the hard disk drive, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Services Media Library), then select Hard disk drive from the menu on the upper left hand side of the screen.
Click here to view the hard disk drive removal video (right-click on the link to open in a new window/tab).
Hard disk drive removal
Observe all precautions when removing and replacing components.
  2. Loosen the four captive P1 Phillips-head screws that secure the hard disk drive to the base enclosure.
  3. Pull the Mylar tab out from under its storage slot on the hard disk drive carrier.
  4. Lift the Mylar tab to disconnect the hard disk drive from the system board and lift it out of the base enclosure.
  5. Remove the four 3-mm P1 Phillips-head screws that secure the hard disk drive carrier to the hard disk drive.
  6. Lift and remove the hard disk drive from the hard disk drive carrier.
  7. Disconnect the SATA adapter from the hard disk drive.
  8. Place the hard disk drive in a static dissipative bag.
Hard disk drive replacement
  1. Remove the hard disk drive from the static dissipative bag.
  2. Connect the SATA adapter to the hard disk drive.
  3. Place the hard disk drive on to the hard disk drive carrier.
  4. Replace the four 3-mm P1 Phillips-head screws to secure the hard disk drive to the hard disk drive carrier.
  5. Align the hard disk drive into the hard disk drive bay.
  6. Press the hard disk drive down until it is fully seated into its connector on the system board.
  7. Tighten the four captive P1 Phillips-head screws to secure the hard disk drive to the base enclosure.
  8. Tuck the Mylar tab back into its storage slot on the hard disk drive carrier.
