HP EliteBook 2560p Notebook PC - Removing and Replacing the Battery
This document is provided to assist in removing and replacing the battery for the HP EliteBook 2560p Notebook PC.
Minimum skill level
The end user requires no hardware-specific training to replace the defective part. The end user should have familiarity with system hardware and software requiring repair.
Parts required
The replacement part number will vary depending on the battery that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
9-cell, 100-Wh, 3.0-Ah, Li-ion battery
632423-001 (Modified)
Yes
6-cell, 62-Wh, 2.8-Ah, Li-ion battery
632421-001 (Modified)
Yes
6-cell, 55-Wh, 2.8-Ah, Li-ion long-life battery
632419-001 (Modified)
Yes
3-cell, 31-Wh, 2.8-Ah, Li-ion battery
632417-001 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the battery, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Services Media Library), then select Battery from the menu on the upper left hand side of the screen.
Click here to view the battery removal video (right-click on the link to open in a new window/tab).
Battery removal
  2. Slide the battery release latch in the direction of its battery icon.
  3. Remove the battery by sliding it out of the battery bay.
Battery replacement
To avoid damaging the battery locking mechanism, be sure that the battery release latch is in the unlocked position.
  1. Align the battery with the slide rails in the battery bay.
  2. Slide the battery towards the front of the unit until it clicks into place.
