HP EliteBook 2760p Tablet PC - Removing and Replacing the Hard Disk Drive
This document is provided to assist in removing and replacing the hard disk drive for the HP EliteBook 2760p Tablet PC.
Minimum skill level
Tools required
Small, Phillips-head P1 screwdriver
Parts required
The replacement part number will vary depending on the hard disk drive that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
320GB, 7200 rpm, SATA 7 mm (2.5 in), self-encrypting drive (SED)
656621-001 (Modified)
Yes
656620-001 (Modified)
Yes
250GB, 7200 rpm, SATA 7 mm (2.5 in)
656619-001 (Modified)
Yes
128GB solid-state drive
653017-001 (Modified)
Yes
160GB solid-state drive
653018-001 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the hard disk drive, click on the link below. Or use the product video listing on the HP Services Media Library, (Click here to go to HP Service Media Library), then select Hard disk drive from the menu on the upper left hand side of the screen.
Click here to view the hard disk drive removal video (right-click on the link to open in a new window/tab).
Hard disk drive removal
    Observe all precautions when removing and replacing components.
  2. Remove the 3-mm P1 Phillips-head screw that secures the hard disk drive to the base enclosure.
  3. Loosen the captive P1 Phillips-head screw that secures the hard disk drive to the base enclosure.
  4. Grasp the Mylar tab and slide the hard disk drive toward the front of the tablet to disconnect it from the system board.
  5. Lift the hard disk drive and carrier out of the base enclosure.
  6. Remove the four 3-mm P1 Phillips-head screws that secure the hard disk drive carrier to the hard disk drive.
  7. Lift and remove the hard disk drive from the hard disk drive carrier.
  8. Place the hard disk drive in a static dissipative bag.
Hard disk drive replacement
  1. Remove the hard disk drive from the static dissipative bag.
  2. Place the hard disk drive on to the hard disk drive carrier.
  3. Replace the four 3-mm P1 Phillips-head screws to secure the hard disk drive to the hard disk drive carrier.
  4. Place the hard disk drive into the hard disk drive bay.
  5. Grasp the Mylar tab and slide the hard drive toward the rear of the tablet until it is fully seated into its connector on the system board.
  6. Tighten the captive P1 Phillips-head screw to secure the hard disk drive to the base enclosure.
  7. Replace the 3-mm P1 Phillips-head screw to secure the hard disk drive to the base enclosure.
Parts return
