HP ProBook 4435s/4436s Notebook PC - Overview
Product description
Thin, lightweight design with metallic gray brushed aluminum finish for durability and style; wear-resistant HP DuraFinish.
Product features
Feature
Accelerated Processing Unit (APU)1
VISION Technology from AMD
  • AMD Quad-Core A6-3400M with Radeon HD 6520G Graphics (2.3 GHz/1.4 GHz, 4MB L2 cache, 35 W)
  • AMD Quad-Core A6-3400M with Radeon HD 6540G2 Dual Graphics (2.3 GHz/1.4 GHz, 4MB L2 cache, 35 W)
  • AMD Dual-Core A4-3300M with Radeon HD 6480G Graphics (2.5 GHz/1.9 GHz, 2MB L2 cache, 35 W)
  • AMD Dual-Core A4-3300M with Radeon HD 6510G2 Dual Graphics (2.5 GHz/1.9 GHz, 2MB L2 cache, 35 W)
Fusion Controller Hub (Chipset)
AMD A70M FCH
Graphics included with Accelerated Processing Unit (APU)2
Models with integrated graphics (HP 4435s and HP 4535s)
  • AMD Radeon HD 6520G Graphics (with AMD Quad-Core A6-3400M APU)
  • AMD Radeon HD 6480G Graphics (with AMD Dual-Core A4-3300M APU)
Models with discrete graphics (HP 4436s and HP 4535s)
  • AMD Radeon HD 6540G2 Dual Graphics (with AMD Quad-Core A6-3400M APU)
  • AMD Radeon HD 6510G2 Dual Graphics (with AMD Dual-Core A4-3300M APU)
Display3
Internal
  • 14.0-inch diagonal LED-backlit HD anti-glare (1366 x 768 resolution)
  • 14.0-inch diagonal LED-backlit HD BrightView (1366 x 768 resolution)
External
  • Up to 32-bit per pixel color depth
  • VGA port supports resolutions up to 2048 x 1536 at 75 Hz, and lower resolutions at up to 100 Hz.
  • HDMI port supports direct connection to high-definition displays with up to 1920 x 1080 resolution and 7-channel audio with one convenient cable (not included).
Memory
Standard
  • DDR3 PC3-10600 SDRAM (1333 MHz)
  • Two SODIMM slots supporting dual-channel memory
  • 1GB, 2GB and 4GB SODIMMs
Maximum
  • Upgradeable to 8GB with 4GB SODIMMs in slots 1 and 2
Dual-channel
  • Maximized dual-channel performance requires SODIMMs of the same size and speed in both memory slots.
Communications
  • Realtek Ethernet (10/100/1000 NIC)
  • Optional 56K V.92 modem
Keyboard
The HP spill-resistant keyboard is designed using a thin layer of Mylar film under the keyboard and a drain system that funnels fluid through a hole in the bottom of the notebook. This minimizes the risk of damage to sensitive components underneath. The 101/102-key compatible keyboard features a full-pitch key layout with desktop keyboard features, such as editing keys, both left and right control and alt keys, and function keys. US and International key layouts are available. The HP ProBook 4535s includes a separate numeric keypad.
Launch Buttons and Function Keys
Separate launch buttons provide easy access to wireless on/off and HP QuickWeb. Function keys provide control of features including: standby mode, display brightness, external display, HP Power Assistant, volume mute, volume down, volume up, and media control.
Pointing device
  • Touchpad with gestures support
  • On/Off button with LED indicator
  • Two-way scroll
  • Two pick buttons
Expansion card slots
  • ExpressCard/34 slot
    Supports ExpressCard/34 (34 mm x 75 mm x 5 mm) card sizes
  • Media Card Reader
    Supports High Speed SD 3.0 (Secure Digital), MMC (MultiMedia Card), Memory Stick, Memory Stick Pro, Memory Stick Pro Duo, SD Micro, MMC Micro
Internal storage
Hard drives
  • 250/320/500/750GB 7200 rpm SMART SATA II
  • 320/640GB 5400 rpm SMART SATA II
HP 3D DriveGuard (Windows models only)
  • The hard drive is mounted directly to the notebook frame, reducing the transmission of shock to the hard drive. Uses three-axis digital motion detection with intelligent sensitivity to help protect the hard drive during normal use from shock and vibration. The digital accelerometer temporarily halts all data transfer and parks the hard drive when abrupt motion is detected.
Removable storage
Fixed optical drives
  • Blu-ray ROM DVD+/-RW SuperMulti DL Drive
  • DVD+/-RW SuperMulti DL Drive
  • DVD-ROM Drive
Weight saver
Power supply
  • Models with integrated graphics: External 65 W Smart AC adapter
  • Models with discrete graphics: External 90 W Smart AC adapter
  • 1.8 m (6 ft) power cord included; total length including external AC adapter is 3.66 m (12 ft)
  • HP Fast Charge
Battery
Primary battery
  • HP 9-cell (93 WHr) Li-Ion battery
  • HP 6-cell (55 WHr) Li-Ion battery
  • HP 6-cell (47 WHr) Li-Ion battery
1. APU speed denotes maximum performance mode; APUs will run at lower speeds in battery optimization mode.
2. All discrete configurations come with either 512MB or 1GB dedicated DDR3 video memory Microsoft DirectX 11 (Shader Model 5.0) and OpenGL 4.0 capable.
3. Resolutions are dependent upon monitor capability, and resolution and color depth settings.
Software overview
Feature
Preinstalled
  • Genuine Windows 7 Professional 32
  • Genuine Windows 7 Professional 64
  • Genuine Windows 7 Home Premium 32
  • Genuine Windows 7 Home Premium 64
  • Genuine Windows 7 Home Basic 32 (select countries)
  • Genuine Windows 7 Starter (select countries and configurations)
  • SuSE Linux Enterprise Desktop 11
  • FreeDOS
Supported
  • Genuine Vista Home Basic
  • Genuine Windows XP Professional 32
Preinstalled software with Windows Operating System
  • HP Recovery Manager
  • HP Support Assistant
  • HP ProtectTools Security Manager
  • HP ProtectTools for Central Management
  • HP Face Recognition
  • HP Hotkey Support
  • HP QuickWeb
  • HP Power Assistant
  • HP Connection Manager
  • HP DayStarter
  • Microsoft Office 2010 preloaded
  • Norton Internet Security 2011
  • PDF Complete Special Edition
  • ArcSoft Total Media Suite
  • HP Webcam Software (select models)
  • Skype
Additional software available from the web
  • HP SoftPaq Download Manager
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
