HP Compaq LE2202x 21.5-inch LED Backlit LCD Monitor - Specifications
Physical specifications
Specification
Dimensions (H x W x D)
Unpacked with stand:
  • 37.97 x 51.8 x 16 cm (14.9 x 20.4 x 6.3 in)
Unpacked without stand (head only):
  • 31.52 x 51.8 x 4.75 cm (12.4 x 20.4 x 1.9 in)
Packaged:
  • 12.6 x 57.1 x 42.9 cm (5.0 x 22.5 x 16.9 in)
Base area (footprint):
  • 23.85 x 16 cm (9.4 x 6.3 in)
Head only:
  • 3.25 kg (7.17 lb)
Unpacked:
  • 3.9 kg (8.6 lb)
Packaged:
  • 5.1 kg (11.24 lb)
Tilt range
-5° to +25°
Swivel range
No
Height adjustable
No
Pivot rotation
No
Base
Attachable, ships detached
Panel specifications
Specification
Type
Twisted Nematic (TN) LED Backlit LCD
54.61 cm (21.5 in) widescreen; diagonally measured
Screen opening (H x W)
26.8 x 47.6 cm (10.55 x 18.74 in)
Aspect ratio
16:9
Viewing angle (typical)
Up to 170° horizontal/160° vertical (10:1 minimum contrast ratio)
Brightness (typical)1
250 nits (cd/m²)
Contrast ratio (typical)1
1000:1
Dynamic contrast ratio (typical)1
3,000,000:1
Response time (typical)1
5 ms (On/Off)
Pixel pitch
0.24825 mm
Backlight lamp life (to half brightness)
30,000 hours
Color gamut (typical)
72%
Color support2
Display up to 16.7 million colors
1: All performance specifications represent the typical specifications provided by HP's component manufacturers; actual performance may vary either higher or lower.
2: With the use of FRC technology.
On Screen Display (OSD) controls specifications
Specification
Buttons or switches (OSD closed/OSD open)
Menu, Minus (-), Plus/Source (+), OK/Auto and Power
Languages
German, Simplified Chinese, Traditional Chinese, Japanese, English, Spanish, French, Italian, Netherlands, Brazilian Portuguese
User controls
Brightness, contrast, positioning, color temperature (warm, standard, cool, custom), image control (clock, clock phase, scaling, sharpness, DCR), monitor management, source control, information and factory reset
Signal interface/performance specifications
Specification
Horizontal frequency
24 to 94 kHz
Vertical frequency
50 to 76 Hz
Native resolution
1920 x 1080 @ 60 Hz
Preset VESA graphic modes (non-interlaced)
  • 1920 x 1080 @ 60 Hz
  • 1680 x 1050 @ 60 Hz
  • 1440 x 900 @ 60 Hz
  • 1280 x 1024 @ 60 Hz
  • 1280 x 720 @ 60 Hz
  • 1024 x 768 @ 60 Hz
  • 800 x 600 @ 60 Hz
  • 720 x 400 @ 70 Hz
  • 640 x 480 @ 60 Hz
Text mode
720 x 400 @ 70 Hz
Maximum pixel clock speed
  • 200 MHz (VGA)
  • 165 MHz (DVI)
User programmable modes
Yes (20)
Anti-glare
Yes
Default color temperature
6500 K
Video/other inputs specifications
Specification
Plug and play
Yes
Input connectors
  • VGA (analog)
  • DVI-D with HDCP
Input impedance
75 ohms (VGA)
Video cable
  • One 15-pin D-sub (VGA)
  • One DVI-D
Video cable lengths
1.8 m (5.9 ft)
Audio
No
Power specifications
Specification
Input power
100 - 240 V ac, 50 or 60 Hz
Typical power consumption
26 W
Maximum
28 W
Power saving
< 0.5 W
Power cable length
1.9 m (6.2 ft)
Environmental specifications
Specification
Operating temperature
0° to 35°C (32° to 95°F)
Non-operating temperature
-20° to 60°C (-4° to 140°F)
Operating humidity
20% to 80%
Non-operating humidity
5% to 95%, 38.7°C maximum wet-bulb
Operating altitude
0 to 5,000 m (0 to 16,404 ft)
Non-operating altitude
0 to 12,192 m (0 to 40,000 ft)
White LED backlights
Yes
CCFL panel
No
Arsenic-free glass
Yes
BFR/PVC free
Yes (everything except external cables)
Mercury free
Yes
