HP Compaq 6200 Pro Microtower PC - Removing and Replacing the Hard Drive
This document applies to the HP Compaq 8200 Elite Microtower PC.
Before you begin
  • Turn off the computer, and then disconnect all cables. Disconnect the Ethernet or modem cable before disconnecting the power cord.
  • Move the computer to a clear, flat, stable work surface over a non-carpeted floor.
  warning:
Video overview (in English)
To view a video demonstrating the procedure for removing the hard drive, right-click the removing the hard drive video and select Open link in new window/tab. Additional product videos can be found on the HP Service Media Library.
Replacement part information
Part Number
Requires Return
750GB SATA 3 GB/s hard drive - 5,400 RPM - With Native Command Queing (NCQ) and Smart IV technology
632938-001 (Modified)
Yes
1TB SATA 6 GB/s hard drive - 7,200 RPM
636930-001 (Modified)
Yes
500GB SATA 6 GB/s hard drive - 7,200 RPM - With Native Command Queuing (NCQ) and Smart IV technology
636929-001 (Modified)
Yes
320GB SATA 3.0 GB/s hard drive - 7,200 RPM
634824-001 (Modified)
Yes
300GB 10K SATA 3 ECO
639695-001 (Modified)
Yes
300GB 10K SATA2
648963-001 (Modified)
Yes
250GB SATA 6 GB/s hard drive - 7,200 RPM - With Native Command Queuing (NCQ) and Smart IV technology
636927-001 (Modified)
Yes
160GB SATA 3.0 GB/s hard drive - 10,000 RPM
639694-001 (Modified)
Yes
160GB SATA 3 GB/s hard drive - 10,000 RPM, 2.5-inch form factor - With 2.5-inch mounting adapter
508312-001 (Modified)
Yes
160GB SATA interface SSD (Solid State Disk) drive - With 3.5-inch bay adapter bracket and screws
646809-001 (Modified)
Yes
80GB SATA interface SSD (Solid State Disk) drive - Intel branded, 2.5-inch form factor
607817-001 (Modified)
Yes
Part numbers are subject to change. See the HP PartSurfer Website for current part numbers.
If the part requires return, click on the appropriate link below:
For customers in countries/regions with RoHS legislation* (e.g. EU, China, etc.) restricting the use of hazardous substances in electrical equipment. The use of the Original Spare part is regulated by RoHS legislation. If your unit contains a part that is labeled with the Modified Spare number, the Modified Spare must be ordered as the replacement part. If your unit contains a part that is labeled with the Original Spare number, please order the Original Spare as the replacement part. In this case either the Original Spare or the Modified Spare may be shipped which will not affect performance or functionality of the unit.
Removing the hard drive
Perform the following to remove the hard drive:
Review the following safety considerations before performing the following steps. Failure to comply with these safety considerations could result in damage to the product.
Step 1
Remove the side panel.
Step 2
Disconnect the data and power cables from the drive.
Disconnect the cables.
Step 3
Pull out on the green release latch and slide the drive out of the drive cage.
If the replacement drive does not include guide screws, remove and reuse the screws from the original drive or use the spare screws provided on the drive cage.
Remove the hard drive.
Replacing the hard drive
Perform the following to replace the hard drive:
Step 1
Align the guide screws on the drive with the guide slots and slide the drive into the bay until it snaps into place.
Replace the hard drive.
Step 2
Connect the power and data cables to the drive.
Connect the cables.
Step 3
Replace the side panel.
Country: Flag Bulgaria
