Mobile Intel QM67 Express chipset
Graphics
Intel HD Graphics 3000 Microsoft DirectX 10.1 (Shader Model 4.1) and OpenGL 3.0 capable
Display1
Internal:
External:
Up to 32-bit per pixel color depth
Display port supports resolutions up to 2560 x 1600, 30-bit color depth at 60 Hz, and full HD (1920 x 1080) monitors, 24-bit color depth at 120 Hz.
VGA port supports resolutions up to 2048 x 1536 at 75 Hz, and lower resolutions at up to 100 Hz.
Memory2
Standard:
DDR3 PC3-10600 SDRAM (1333 MHz)
Two SODIMM slots supporting dual-channel memory
2GB, 4GB, and 8GB SODIMMs
Maximum:
Dual channel:
Communications
Wireless devices
Mobile Broadband options5:
HP hs2340 HSPA+ Mobile Broadband module:
Integrated mobile broadband module
Connectivity to both HSPA and HSPA+ (UMTS) networks
Standalone, Internet and network assisted GPS functionality for various mapping applications and security applications
HP un2430 EV-DO/HSPA Mobile Broadband module:
Integrated mobile broadband module with Gobi global mobile Internet technology
Connectivity to both CDMA (EVDO) and UMTS (HSPA) networks
All 802.11 integrated wireless LAN options:
Wi-Fi certified6
Cisco Compatible Extensions support
Wired Equivalent Privacy (WEP) support up to 128-bit keys
Wi-Fi Protected Access (WPA) and WPA2 support
802.1x authentication support, including EAP-TLS, EAP-TTLS, PEAP-GTC, PEAP-MSCHAPv2, and LEAP
Advanced Encryption Standard (AES) support
Dual antennas integrated in the display enclosure
Intel Centrino Ultimate-N 6300 (3 x 3):
Integrated support for 802.11a, b, g, and n6
3 transmit, 3 receive antennas
Up to 450 Mb/s data rate
Intel Centrino Advanced-N 6205 (2 x 2):
2 transmit, 2 receive antennas
Up to 300 Mb/s data rate
Broadcom 4313GN 802.11b/g/n
WiFi adapter:
1 transmit, 1 receive antenna
Up to 72 Mb/s data rate
Broadcom 43224AGN 802.11a/b/g/n
(2 x 2) WiFi adapter:
HP Integrated Module with Bluetooth 2.1+EDR wireless technology:
Keyboard
101/102-key compatible keyboard
International key layouts
Editing keys, both left and right control and alt keys, function keys, 19 x 19 mm key pitch (center-to-center spacing), 2.0 mm stroke, and comfort-dished keycaps
Pointing device
Touchpad with On/Off button, two-way scroll, gestures, two pick buttons
Pointstick with two additional pointstick buttons
Expansion card slots
ExpressCard/54 slot:
Integrated Smart Card Reader:
Secure Digital/MMC slot:
Internal storage
Hard drives7:
HP 3D DriveGuard (Windows only):
Solid State drive:
Interfaces
External monitor: Two (one display port and one VGA port)
Combo headphone/microphone jack: One
Power connector: One
RJ-11/modem:
One
RJ-45/Ethernet: One
USB 2.0: Two (including the charging port)
eSATA/USB 2.0 combo:
One
Docking connector:
For HP 2560 Series Docking Station
Audio
SRS premium sound
Integrated stereo speakers
Integrated dual-microphone array
Button for volume mute; function keys for volume up and down
Visual
Optional 720p HD webcam:
HD format (widescreen)
Supports videoconferencing and still image capture
High quality fixed focus lens
Video capture at various resolutions up to 1280 x 720 resolution (720p) and up to 30 f/s
M-JPEG compression supports higher frame rates for video capture and videoconferencing
Improved low light sensitivity
Improved dynamic range
Power supply
External 90-W Smart AC adapter
Power cord included: 1.8 m (6 ft)
Total length including external AC adapter: 3.66 m (12 ft)
HP Fast Charge8
Battery
Primary battery:
HP 9-cell (100 WHr) Li-Ion battery
HP 6-cell (62 WHr) Li-Ion battery
HP 3-cell 31 WHr Li-Ion primary battery
HP Long Life 6-cell (55 WHr) Li-Ion battery
Battery life9
9-cell (100 WHr):
6-cell (62 WHr):
HP 3-cell primary battery:
1: Resolutions are dependent upon monitor capability, and resolution and color depth settings.
2: Due to the non-industry standard nature of some third-party memory modules, we recommend HP branded memory to ensure compatibility. If memory speeds are mixed, the system will perform at the lower memory speed. Full availability of 4GB or more of memory requires a Windows 64-bit operating system or Linux. With Windows 32-bit operating systems, the amount of usable memory is dependent upon the configuration, so that above 3GB all memory may not be available due to system resource requirements.
3: The term "10/100/1000" or "Gigabit" Ethernet indicates compatibility with IEEE standard 802.3ab for Gigabit Ethernet, and does not connote actual operating speed of 1 Gb/s. For high-speed transmission, connection to a Gigabit Ethernet server and network infrastructure is required.
4: Designed for downloads from 56K modem compliant sources. Maximum achievable download transmission rates currently do not reach 56 KB/s, and will vary with line conditions. Modem availability is subject to country regulatory approval.
5: Separately purchased mobile network operator service is required.
6: In countries where 802.11n is not allowed, this capability is not enabled (802.11a/b/g only).
7: These hard drives are customer removable and will withstand multiple insertion/removal cycles. Up to 20GB is reserved for the system recovery software.
8: HP Fast Charge recharges your battery up to 90% within 90 minutes when the system is off. Fast Charge Technology does not apply to 9-cell primary batteries.
9: Battery life will vary depending on the product model, configuration, loaded applications, features, use, wireless functionality and power management settings. The maximum capacity of the battery will naturally decrease with time and usage.
