    Windows 11 Upgrade Guide
     Connect with HP support faster, manage all of your devices in one place, view warranty information and more. Sign up for an HP account
HP EliteBook 8560w Mobile Workstation Specifications
Product description
The most versatile mobile workstation graphics card with HP Professional high performance, extreme processing power, display 15.6-inch diagonal and a tailored design that exudes performance.
Product features
Feature
Mobile Intel QM67 Express Chipset
Processors1
2nd Generation Intel Core i7 Processors
  • Intel Core i7-2820QM Processor (2.30 GHz, 8MB L3 cache, 4 cores/8 threads, 45 W) Up to 3.40 GHz with Intel Turbo Boost Technology
  • Intel Core i7-2720QM Processor (2.20 GHz, 6MB L3 cache, 4 cores/8 threads, 45 W) Up to 3.30 GHz with Intel Turbo Boost Technology
  • Intel Core i7-2630QM Processor (2.00 GHz, 6MB L3 cache, 4 cores/8 threads, 45 W) Up to 2.90 GHz with Intel Turbo Boost Technology
  • Intel Core i7-2620M Processor (2.70 GHz, 4MB L3 cache, 2 cores/4 threads, 35 W) Up to 3.40 GHz with Intel Turbo Boost Technology
2nd Generation Intel Core i5 Processors
  • Intel Core i5-2540M Processor (2.60 GHz, 3MB L3 cache, 2 cores/4 threads, 35 W) Up to 3.30 GHz with Intel Turbo Boost Technology
  • Intel Core i5-2520M Processor (2.50 GHz, 3MB L3 cache, 2 cores/4 threads, 35 W) Up to 3.20 GHz with Intel Turbo Boost Technology
Graphics
  • AMD FirePro M5950 with 1GB dedicated GDDR5 video memory (Microsoft DirectX 11 (Shader Model 5.0) and OpenGL 4.0 capable)
  • AMD Eyefinity Technology supports up to five independent displays (requires discrete graphics configuration) when using an HP Advanced Docking station.
  • NVIDIA Quadro 1000M with 2GB dedicated DDR3 video memory (Microsoft DirectX 11 (Shader Model 5.0) and OpenGL 4.0 capable)
  • NVIDIA Quadro 2000M with 2GB dedicated DDR3 video memory (Microsoft DirectX 11 (Shader Model 5.0) and OpenGL 4.0 capable)
Display2
Internal
  • 15.6-inch diagonal LED-backlit HD+ WVA anti-glare (1600 x 900 resolution)
  • 15.6-inch diagonal LED-backlit FHD WVA anti-glare (1920 x 1080 resolution)
  • 15.6-inch diagonal LED-backlit FHD UWVA anti-glare DreamColor (1920 x 1080 resolution)
  • Ambient Light Sensor
  • Optional HP Privacy Filter
External (Up to 32-bit per pixel color depth)
  • DisplayPort supports resolutions up to 2560 x 1600, 30-bit color depth at 60 Hz, and full HD (1920 x 1080) monitors, 24-bit color depth at 120 Hz.
  • VGA port supports resolutions up to 2048 x 1536 at 75 Hz, and lower resolutions at up to 100 Hz.
  • DVI-D (single link) video signal available through DVI port in optional HP Docking Station (sold separately) supports resolutions up to 1600 x 1200 at both full and reduced blanking, and 1920 x 1200 at reduced blanking.
Memory3
Standard
  • DDR3 PC3-10600 SDRAM (1,333 MHz)
  • Two or four SODIMM slots supporting dual-channel memory
  • 2GB, 4GB and 8GB SODIMMs
Maximum
  • Upgradeable to 32GB with (4) 8GB SODIMMs
Dual-channel
  • Maximized dual-channel performance requires SODIMMs of the same size and speed in both memory slots.
Communications4
  • Integrated Intel 82579LM Gigabit Network Connection
  • 56K V.92 modem
Keyboard
The HP spill-resistant keyboard is designed using a thin layer of Mylar film under the keyboard and a drain system that funnels fluid through a hole in the bottom of the notebook. This minimizes the risk of damage to sensitive components underneath. The 101/102-key compatible keyboard features a full-pitch key layout with desktop keyboard features such as editing keys, both left and right control and alt keys, function keys, and 19.05 x 19.05 mm key pitch (center-to-center spacing). U.S. and International key layouts are available. Other features include hot keys for instant access to power conservation and brightness and a separate numeric keypad.
Launch buttons and function keys
Separate launch buttons provide easy access to the following features:
  • Wireless on/off
  • Volume mute
  • HP QuickWeb
  • Calculator launch button
Function keys provide control of the following features:
  • Standby mode
  • External display
  • Volume down
  • Volume up
  • HP Power Assistant
  • Display brightness
Pointing device
  • Touchpad with on/off button (double-tap to activate/de-activate), two-way scroll, gestures, three pick buttons.
  • Pointstick with three additional pointstick buttons.
Internal storage
Hard drives
  • 320/500/750GB 7200 rpm SMART SATA II
  • 320GB 7200 rpm SMART SATA II Self Encrypting Drive
HP 3D DriveGuard (Windows only)
  • The hard drive is mounted directly to the notebook frame, reducing the transmission of shock to the hard drive. Uses three-axis digital motion detection with intelligent sensitivity to help protect the hard drive during normal use from shock and vibration. The digital accelerometer temporarily halts all data transfer and parks the hard drive when abrupt motion is detected.
Solid State Drive
  • 128/256GB
Expansion card slots
  • Supports ExpressCard/54
  • Compatible with ISO 7816-compliant Smart Cards PC/SC interface support.
  • Supports SD (Secure Digital), MMC (MultiMedia Card)
Battery
Primary battery
  • HP 8-cell (83 WHr) Li-Ion battery
  • HP Long Life 8-cell (75 WHr) Li-Ion battery
Secondary battery options
  • HP BB09 Ultra Extended Life Notebook Battery (9 cell, 100 WHr)
  • HP ST09 Extended Life Notebook Battery (9 cell, 73 WHr)
System standby time
Up to 1 week
1. Intel’s numbering is not a measurement of higher performance. Processor speed denotes maximum performance mode; processors will run at lower speeds in battery optimization mode.
2. Resolutions are dependent upon monitor capability, resolution and color depth settings.
3. Due to the non-industry standard nature of some third-party memory modules, we recommend HP branded memory to ensure compatibility. If one mix memory speeds, the system will perform at the lower memory speed. Full availability of 4GB or more of memory requires a Windows 64-bit operating system or Linux. With Windows 32-bit operating systems, the amount of usable memory is dependent upon your configuration, so that above 3GB all memory may not be available due to system resource requirements.
4. The term 10/100/1000 or Gigabit Ethernet indicates compatibility with IEEE standard 802.3ab for Gigabit Ethernet, and does not connote actual operating speed of 1 Gb/s. For high-speed transmission, connection to a Gigabit Ethernet server and network infrastructure is required. 56K V.92 modem designed for downloads from 56K modem compliant sources. Maximum achievable download transmission rates currently do not reach 56 KB/s, and will vary with line conditions. Modem availability is subject to country regulatory approval.
Audio/Visual
Specification
Audio/Visual
  • SRS Premium Sound
  • Integrated stereo speakers
  • Dual-microphone array
  • Button for volume mute; function keys for volume up and down
  • Stereo headphone/line out
  • Stereo microphone/line in
  • Optional 720p HD webcam
    • HD format (widescreen)
    • Supports video conferencing and still image capture
    • High quality fixed focus lens
    • Video capture at various resolutions up to 1280 x 720 resolution (720p) and up to 30 f/s
    • M-JPEG compression supports higher frame rates for video capture and videoconferencing
    • Improved low-light sensitivity
    • Improved dynamic range
Electrical specifications
Specification
Stand-alone power requirements (AC Power)
Nominal operating voltage
  • 19.5 V
Average operating power
  • 42 W
Maximum operating power
  • < 120 W , < 150 W or < 200 W
Physical specifications
Specification
Dimensions1 (H x W x D)
34.5 (front)/38.4 (rear) x 382.0 x 257.5 mm (1.36 (front)/1.51 (rear) x 15.0 x 10.1 in)
Height with DreamColor display:
  • Front
    • 36.5 mm (1.44 in)
  • Rear
    • 40.4 mm (1.59 in)
  • Starting at 3.0 kg (6.69 lb) with SSD (no optical drive)
  • Starting at 3.1 kg (6.94 lb) with hard drive and DVD-ROM drive
Height varies depending upon where on the notebook the measurement is made. Weight varies by configuration and components. Weight includes 8-cell battery and WLAN.
Software/OS
Feature
Preinstalled software with Windows operating system
  • HP Performance Advisor
  • HP Mobile Display Assistant (with HP DreamColor Technology)
  • HP Recovery Manager
  • HP Support Assistant
  • HP ProtectTools Security Manager
  • HP ProtectTools for Central Management
  • HP Hotkey Support
  • HP QuickWeb
  • HP Connection Manager 4.0
  • HP DayStarter
  • Microsoft Office 2010 preloaded (purchase of a Product Key required to activate a full Office 2010 suite)
  • Norton Internet Security 2011
  • PDF Complete Special Edition
  • Intervideo WinDVD – DVD Player (select models)
  • Roxio Burn Secure (select models)
  • Roxio MyDVD 10 SE (select models)
  • HP Webcam Software (select models)
  • Skype
Additional software available from the web
  • HP SoftPaq Download Manager
  • HP Client Manager Software
  • HP Client Configuration Management Agent
Environmental specifications
Specification
Temperature
Operating
  • 0° to 35°C (32° to 95°F) (not writing optical)
  • 5° to 35°C (41° to 95°F) (writing optical)
Non-operating
  • –20° to 60°C (–4° to 140°F)
Relative humidity
Operating
  • 10% to 90%, noncondensing
Non-operating
  • 5% to 95%, 38.7°C (101.6°F) maximum wet bulb temperature
Shock
Operating
  • 125 G, 2 ms, half-sine
Non-operating
  • 200 G, 2 ms, half-sine
Random vibration
Operating
  • 0.75 grms
Non-operating
  • 1.50 grms
Altitude (unpressurized)
Operating
  • –15.24 to 3,048 m (–50 to 10,000 ft)
Non-operating
  • –15.24 to 12,192 m (–50 to 40,000 ft)
Safety certifications
Certifications
Industry Standard Certifications
UL
Yes
CSA
Yes
FCC Compliance
Yes
ENERGY STAR1
Select models
EPEAT2
Gold target
ICES
Yes
Australia/NZ A-Tick Compliance
Yes
CCC
Yes
Japan VCCI Compliance
Yes
KCC
Yes
BSMI
Yes
CE Marking Compliance
Yes
1. Microsoft Windows is required for ENERGY STAR qualification. Configurations of the HP EliteBook 8560w that are ENERGY STAR qualified are identified as HP EliteBook 8560w ENERGY STAR on HP websites and on Energy Star website.
2. EPEAT Registered TBD in U.S. EPEAT registration varies by country/region.
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
