HP Scitex LX600, LX800, LX820, LX850 and Designjet L65500 Printer Series - Installing the HP Internal Print Server (L65500)
Install the HP IPS software
If necessary, the HP Internal Print Server executable file can be found on the web at http://www.hp.com under the Support & Drivers tab.
  1. Find the setup.exe icon on the desktop, double click on the icon and follow the on-screen instructions.
  2. From the Internal Print Server, navigate to Tools > Proactive support. Configure the HP Proactive Support and make sure the customer accepts all disclaimers.
  3. From the Internal Print Server, navigate to Tools > Proactive support. Configure the HP Proactive Support and make sure the customer accepts all disclaimers
How to change the country language of the IPS
  1. Navigate to the Control Panel on the Internal Print Server and select Clock, Language, and Region.
  2. Select the appropriate entry from the format list.
Create a shared folder
  1. Create a folder named OutJobs on the HP Internal Print Server PC.
  2. Open the folder properties for the new OutJobs folder and navigate to the Sharing tab.
  3. Click Advanced Sharing to set the sharing properties.
  4. Make sure that Share this folder is selected.
  5. Set the other settings to your requirements, then click Permissions.
  6. Add any groups or users required, and set the permissions as required by the customer.
  7. Navigate to Control Panel/Network and Internet/Network and Sharing Center on Windows Vista, and make sure that File Sharing is turned on.
