HP 630/631 Notebook PC Product Specifications
Product description
The HP 630/631 Notebook PC is a tool for success. This notebook has a sophisticated design with a smooth matte surface and an understated pewter color for a clean professional look.
Product features
Feature
  • Mobile Intel GM45 Express Chipset with ICH9M
  • Mobile Intel HM55 Express Chipset
  • Mobile Intel HM65 Express Chipset
Processors
  • Intel Core 2 Duo T6670 (2.20 Hz) 800 MHz/2M L3
  • Intel Celeron Processor T3500 (2.10 GHz / 800 MHz FSB/1MB L2)
  • Intel Celeron Processor T3300 (2.0 GHz / 800 MHz FSB/1MB L2)
  • Intel Celeron Processor 925 (2.3 GHZ / 800 MHz FSB/ 1M Cache)
  • Intel Celeron Processor 900 (2.20 GHZ / 800 MHz FSB/ 1M Cache)
  • Intel Pentium Processor P6300 (2.26 GHz, 3MB L3 Cache)
  • Intel Pentium Processor P6200 (2.13 GHz, 3MB L3 Cache)
  • 2nd generation Intel Core i5-2540M Processor (2.6 GHz, 3MB L3 Cache)
  • 2nd generation Intel Core i5-2520M Processor (2.5 GHz, 3MB L3 Cache)
  • 2nd generation Intel Core i5-2410M Processor (2.3 GHz, 3MB L3 Cache)
  • 2nd generation Intel Core i3-2310M Processor (2.1 GHz, 3MB L3 Cache)
  • Intel Pentium B950 Processor (2.10 GHz, 2MB L3 Cache)
  • Intel Pentium B940 Processor (2.00 GHz, 2MB L3 Cache)
Memory
Standard: DDR3 SDRAM (800 MHz/1066 MHz/1333 MHz) Two SODIMM slots supporting dual-channel memory 1024MB and 2048MB SODIMMs. Standard memory up to 4096MB
Maximum : Upgradeable to 8192MB with optional 4096MB SODIMMs in slots 1 and 2
Dual-channel: Maximized dual-channel performance requires SODIMMs of the same size and speed in both memory slots.
Graphics
Models with Mobile Intel GM45 Express Chipset with ICH9M : Integrated: Intel Graphics Media Accelerator 4500MHD
Models with Intel HM55 Express Chipset:
  • Integrated: Intel HD Graphics
  • Discrete: Radeon HD 6370M Graphics with 512MB of dedicated video memory
Models with Intel HM65 Express Chipset:
  • Integrated: Intel HD Graphics 3000
  • Discrete: Radeon HD 6470M Graphics with 512MB of dedicated video memory
  • Discrete: Radeon HD 6470M Graphics with 1024MB of dedicated video memory
Support for BD and/or HD-DVD playback with HD Decode , and DX10(for Integrated)/DX11 (for Discrete) Support
Internal:
  1. 15.6-inch diagonal LED-backlit HD 16:9 widescreen Anti-Glare (1366 x 768 resolution)
  2. 15.6-inch diagonal LED-backlit HD 16:9 widescreen BrightView (1366 x 768 resolution)
External: Up to 32-bit per pixel color depth
VGA port supports resolutions up to 2048 x 1536 external resolution @75 Hz
HDMI port supports up to 1080p, 1920x1080 at 60Hz and 1920x1200 @ 60Hz DVI Mode
Keyboard
The 100% compatible keyboard features a, industry standard, full-pitch key layout with features such as the isolated inverted-T cursor control keys, editing keys, both left and right control and alt keys, and 12 function keys. International key layouts are available. Other features include hotkeys for instant access to, brightness, etc. 19-mm x 19-mm key pitch (center-to-center spacing), 2.2-mm stroke, comfort-dished keycaps, and bright key legends for improved visibility in low light conditions.
Pointing device
Touchpad with 2-piece pick button with left and right click functions, Multi-touch gestures supported, On/off button
Expansion card slots
Digital Media slot:
  • Supports SD (Secure Digital), and MMC (MultiMedia Card)
  • Supports mini versions with adapter
Power supply
External 65 W or 90 W smart pin design AC adapter.
Battery
HP 6-cell (47 WHr) Li-Ion battery
Communications
Features
Integrated Realtek RTL8165EH-CG 10/100 NIC Integrated Realtek RTL8111E 10/100/1000 NIC
Ethernet Features:
  • 10 Mb/s operation (10BASE-T; IEEE 802.3i; IEEE 802.3 clauses 13-14)
  • 100 Mb/s operation (100BASE-TX; IEEE 802.3u; IEEE 802.3 clauses 21-30)
  • 1000 Mb/s operation (100BASE-T; IEEE 802.3ab; IEEE 802.3 clauses 21-30) (Support in RTL8111E only)
Audio/Visual
Features
Audio/Visual
  • High Definition Audio support
  • Integrated microphone
  • Integrated stereo speaker (Altec Lansing)
  • Headphone/line out
  • Microphone in
  • Optional VGA webcam:
    • Supports videoconferencing and still image capture
    • Improved quality for video streaming and still image capture (640x480 resolution)
    • Up to 24 frames/sec
    • Fixed focus lens
Hardware specifications
Features
Dimensions (HxWxD)
376 x 247 x 31.8 mm (14.80 x 9.72 x 1.25 in)
Starting at 2.50 kg (5.5 lb)
Stand-Alone power requirements (AC Power)
  • Normal Operating Voltage: 18.5 V
  • Max Operating power: <65 W
Temperature
Operating:
0° to 35°C (32° to 95°F) (not writing optical)
5° to 35°C (41° to 95°F) (writing optical)
Non-operating: -20° to 60°C (-4° to 140°F)
Relative humidity
Operating: 10% to 90%, non-condensing
Non-operating: 5% to 95%, 38.7°C (101.6°F) maximum wet bulb temperature
Altitude (unpressurized)
Operating: -15.24 to 3,048 m (-50 to 10,000 ft)
Non-operating: -15.24 to 12,192 m (-50 to 40,000 ft)
Software/OS
Feature
Operating System
  • Genuine Windows 7 Professional 32
  • Genuine Windows 7 Home Premium 32
  • Genuine Windows 7 Home Basic 32
  • Genuine Windows 7 Starter 32
  • Genuine Windows 7 Professional 64
  • Genuine Windows 7 Home Premium 64
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
