HP Color LaserJet CP3525 Series Printer - Replace the Print Cartridges
To view a video demonstrating the procedure for removing the part click here to access the Services Media Library (www.hp.com/go/sml). Select Printers and Multifunction under the Product category, select HP Color LaserJet Printers under the Product family, and then select the printer model under the product series category.
Print cartridge replacement
  1. Open the front door. Make sure that the door is completely open.
  2. Grasp the handle of the used print cartridge and pull out to remove.
  3. Store the used print cartridge in a protective bag. Information about recycling used print cartridges is on the print-cartridge box.
  4. Remove the new print cartridge from its protective bag.
    Be careful not to damage the memory tag on the print cartridge.
  5. Grasp both sides of the print cartridge and distribute the toner by gently rocking the print cartridge.
  6. Remove the orange protective cover from the print cartridge.
    Avoid prolonged exposure to light.
    Do not touch the green roller. Doing so can damage the cartridge.
  7. Align the print cartridge with its slot and insert the print cartridge until it clicks into place.
  8. Close the front door.
Parts return
