HP Color LaserJet CP3525 Series Printer - Replace the Intermediate Transfer Belt (ITB)
To view a video demonstrating the procedure for removing the part click here to access the Services Media Library (www.hp.com/go/sml). Select Printers and Multifunction under the Product category, select HP Color LaserJet Printers under the Product family, and then select the printer model under the product series category.
Intermediate transfer belt (ITB) replacement
Do not touch the black-plastic belt. Skin oils and fingerprints on the belt can cause printquality problems. Always place the ITB on a flat surface in a safe and protected location.
  1. Open the right-door assembly.
  2. Use the blue lever (callout 1) to lower the secondary transfer assembly.
  3. Grasp the small handles on the ITB and then pull the ITB out of the product until two large handles expand along the right- and left-side of the ITB.
  4. Grasp the large handles on the ITB and then pull the ITB straight out of the product to remove it.
    The ITB is a sensitive component. Be careful when handling the ITB so that it is not damaged. Always place the ITB in a safe and protected location.
    If you are installing a replacement ITB, make sure that you remove all of the packing tape (callout 1) and the protective cover sheet (callout 2).
Parts return
