HP EliteBook 8560p Notebook PC Product Specifications
Product features
Feature
Mobile Intel QM67 Express Chipset
Processors
2nd Generation Intel Core i7 Processors:
  • Intel Core i7-2820QM Processor (2.30-GHz, 8MB L3 cache, 4 cores/8 threads, 45W) Up to 3.40 GHz with Intel Turbo Boost Technology
  • Intel Core i7-2720QM Processor (2.20-GHz, 6MB L3 cache, 4 cores/8 threads, 45W) Up to 3.30 GHz with Intel Turbo Boost Technology
  • Intel Core i7-2630QM Processor (2.00-GHz, 6MB L3 cache, 4 cores/8 threads, 45W) Up to 2.90 GHz with Intel Turbo Boost Technology
  • Intel Core i7-2620M Processor (2.70-GHz, 4MB L3 cache, 2 cores/4 threads, 35W) Up to 3.40 GHz with Intel Turbo Boost Technology
2nd Generation Intel Core i5 Processors:
  • Intel Core i5-2540M Processor (2.60-GHz, 3MB L3 cache, 2 cores/4 threads, 35W) Up to 3.30 GHz with Intel Turbo Boost Technology
  • Intel Core i5-2520M Processor (2.50-GHz, 3MB L3 cache, 2 cores/4 threads, 35W) Up to 3.20 GHz with Intel Turbo Boost Technology
  • Intel Core i5-2410M Processor (2.30-GHz, 3MB L3 cache, 2 cores/4 threads, 35W) Up to 2.90 GHz with Intel Turbo Boost Technology
2nd Generation Intel Core i3 Processor: Intel Core i3-2310M Processor (2.10-GHz, 3MB L3 cache, 2 cores/4 threads, 35W)
Graphics
  • Models with discrete graphics AMD Radeon HD 6470M with 1GB dedicated DDR3 video memory Microsoft DirectX 11 (Shader Model 5.0) and OpenGL 4.0 capable.
    AMD Eyefinity Technology supports up to four independent displays when using an HP Advanced Docking station.
  • Models with integrated graphics: Intel HD Graphics 3000
    Microsoft DirectX 10.1 (Shader Model 4.1) and OpenGL 3.0 capable
Memory5
  • Standard:
    • DDR3 PC3-10600 SDRAM (1333 MHz)
    • Two SODIMM slots supporting dual-channel memory
    • 2GB, 4GB, and 8GB SODIMMs
  • Maximum: Upgradeable to 16GB with 8GB SODIMMs in slots 1 and 2
  • Dual-channel: Maximized dual-channel performance requires SODIMMs of the same size and speed in both memory slots.
  • Internal:
    • 15.6-inch diagonal LED-backlit HD anti-glare (1366 x 768 resolution)
    • 15.6-inch diagonal LED-backlit HD+ WVA anti-glare (1600 x 900 resolution)
    • 15.6-inch diagonal LED-backlit FHD WVA anti-glare (1920 x 1080 resolution)
  • External:
    • Up to 32-bit per pixel color depth
    • DisplayPort supports resolutions up to 2560 x 1600, 30-bit color depth at 60 Hz, and full HD (1920 x 1080) monitors, 24-bit color depth at 120 Hz
    • VGA port supports resolutions up to 2048 x 1536 at 75 Hz, and lower resolutions at up to 100 Hz
    • DVI-D (single link) video signal available through DVI port in optional HP Docking Station (sold separately) supports resolutions up to 1600 x 1200 at both full and reduced blanking, and 1920 x 1200 at reduced blanking
Wireless devices
  • HP hs2340 HSPA+ Mobile Broadband Module
  • HP un2430 EVDO/ HSPA Mobile Broadband Module (not available at product introduction)
  • All 802.11 integrated wireless LAN options
  • Intel Centrino Advanced - N 6205 (2 x 2)
  • Intel Centrino Wireless - N 1000 (1 x 2)
  • Broadcom 43224AGN 802.11a/b/g/n WiFi Adapter
  • Broadcom 4313GN 802.11b/g/n WiFi Adapter
Keyboard
The HP spill-resistant keyboard is designed using a thin layer of Mylar film under the keyboard and a drain system that funnels fluid through a hole in the bottom of the notebook. This minimizes the risk of damage to sensitive components underneath. The 101/102-key compatible keyboard features a fullpitch key layout with desktop keyboard features, such as the isolated inverted-T cursor control keys, editing keys, both left and right control and alt keys, 12 function keys, and 19.05 x 19.05 mm key pitch (center-to-center spacing). U.S. and International key layouts are available. Other features include hot keys for instant access to power conservation and brightness. The HP ProBook 6560b includes a separate numeric keypad.
Launch buttons and function keys
Separate launch buttons provide easy access to the following features: wireless on/off, HP QuickWeb, and volume mute. The HP ProBook 6560b also features a calculator launch button. Function keys provide control of the following features: standby mode, external display, volume down, volume up, HP Power Assistant, and display brightness.
Pointing device
  • Touchpad with on/off button, two-way scroll, gestures, two pick buttons
  • Optional pointstick with two additional pointstick buttons
Expansion card slots
  • ExpressCard/54 slot: Supports ExpressCard/54
    Or
  • Optional integrated smart card reader (replaces ExpressCard/54 slot): Compatible with ISO 7816 compliant Smart Cards PC/SC interface support
  • Secure digital slot: Supports SD (Secure Digital), MMC (MultiMedia Card)
Audio/Visual
  • SRS Premium Sound
  • Integrated stereo speakers
  • Integrated microphone (dual-microphone array when equipped with optional webcam)
  • Button for volume mute; function keys for volume up and down
  • Stereo headphone/line out
  • Stereo microphone/line in
Optional 720p HD webcam:
  • HD format (widescreen)
  • Supports videoconferencing and still image capture
  • High quality fixed focus lens
  • Video capture at various resolutions up to 1280 x 720 resolution (720 p) and up to 30 fps
  • M-JPEG compression supports higher frame rates for video capture and videoconferencing
  • Improved low light sensitivity
  • Improved dynamic range
Power supply
  • Models with discrete graphics or quad-core processor: External 90 W Smart AC adapter
  • Models with integrated graphics and without quad-core processor: External 65 W Smart AC adapter
Physical specifications
Feature
Dimensions (H x W x D)
  • 1.35 in (at front) x 14.72 in x 9.86 in
  • 34.1 mm (at front) x 374 mm x 250.5 mm
  • Starting at 2.73 kg (6.01 lb) with hard drive and weight saver (no optical drive)
  • Starting at 2.85 kg (6.27 lb) with hard drive and DVD-ROM drive
Height varies depending upon where on the notebook the measurement is made. Weight varies by configuration and components. Weight includes 3-cell battery and WLAN.
Software overview
Feature
  • Preinstalled:
    • Genuine Microsoft Windows 7 Professional 321
    • Genuine Microsoft Windows 7 Professional 641
    • Genuine Microsoft Windows 7 Home Premium 321
    • Genuine Microsoft Windows 7 Home Premium 641
    • Genuine Microsoft Windows 7 Home Basic 321 (select countries)
    • Genuine Microsoft Windows 7 Starter1 (select countries and configurations)
    • Genuine Microsoft Windows Vista Basic 32
    • SuSE Linux Enterprise Desktop 11
    • FreeDOS
  • Supported:
    • Genuine Microsoft Windows 7 Enterprise 321
    • Genuine Microsoft Windows 7 Enterprise 641
    • Genuine Microsoft Windows 7 Ultimate 321
    • Genuine Microsoft Windows 7 Ultimate 641
    • Genuine Microsoft Windows Vista Enterprise 322
    • Genuine Microsoft Windows Vista Enterprise 642
    • Genuine Microsoft Windows Vista Business 322
    • Genuine Microsoft Windows Vista Business 642
    • Genuine Microsoft Windows XP Professional 32
  • Certified: SuSE Linux Enterprise Desktop 11
1: System may require upgraded and/or separately purchased hardware and/or a DVD drive to install the Microsoft Windows 7 software and take full advantage of Microsoft Windows 7 functionality.
2: Certain Microsoft Windows Vista product features require advanced or additional hardware.
Microsoft Windows Vista Upgrade Advisor can help you determine which features of Windows Vista will run on your computer.
The above web link will take you outside the HP website. HP does not control and is not responsible for the information located outside the HP website.
Environmental specifications
Feature
Temperature
  • Operating1:
    • 0° to 35°C (32° to 95°F) (not writing optical)
    • 5° to 35°C (41° to 95°F) (writing optical)
  • Non-operating: -20° to 60°C (-4° to 140°F)
Relative humidity
  • Operating: 10% to 90%, non-condensing
  • Non-operating: 5% to 95%, 38.7°C (101.6°F) maximum wet bulb temperature
Altitude
  • Operating: -15.24 to 3,048 m (-50 to 10,000 ft)
  • Non-operating: -15.24 to 12,192 m (1-50 to 40,000 ft)
1:At temperatures above 30°C (86°F), the Intel Core i3-2310M Processor may not run at maximum clock speed.
Safety certifications
Feature
Planned industry standard certifications
  • UL Yes
  • CSA Yes
  • FCC Compliance Yes
  • ENERGY STAR Select models1
  • EPEAT Gold target2
  • ICES Yes
  • Australia / NZ A-Tick Compliance Yes
  • CCC Yes
  • Japan VCCI Compliance Yes
  • KCC Yes
  • BSMI Yes
  • CE Marking Compliance Yes
1: Configurations of the HP ProBook 6360b, HP ProBook 6460b and HP ProBook 6560b that are ENERGY STAR qualified are identified as HP ProBook 6360b ENERGY STAR, HP ProBook 6460b ENERGY STAR and HP ProBook 6560b ENERGY STAR on HP websites.
2: EPEAT Registered TBD in U.S. EPEAT registration varies by country.
