    Windows 11 Upgrade Guide
HP Compaq 8200 Elite Small Form Factor PC Product Specifications
Product description
HP Compaq 8200 Elite Small Form Factor PC has rear I/O which includes (6) USB 2.0 ports, serial port, PS/2 mouse and keyboard ports, RJ-45 network interface, DisplayPort v1.1a and VGA video interfaces, and 3.5 mm audio in/out jacks. It has Intel Q67 Express chipset.
Product features
Feature
Processor
  • Intel Core i7-2600 (3.40 GHz, 8MB cache, 4 cores)
  • Intel Core i5-2500 (3.30 GHz, 6MB cache, 4 cores)
  • Intel Core i5-2400 (3.10 GHz, 6MB cache, 4 cores)
  • Intel Core i3-2120 (3.30 GHz, 3MB cache, 2 cores)
  • Intel Core i3-2100 (3.10 GHz, 3MB cache, 2 cores)
Intel Q67 Express
Memory slots
4 DIMM
Storage1
Internal drive bays:
Two 3.5 in
External drive bays:
  • One 3.5 in
  • Two 5.25 in
Internal drives:
  • SATA (7200 rpm):
    Up to: 1TB
  • SATA (10000 rpm):
    Up to: 300GB
  • SATA Solid State Drive (SSD):
    Up to: 160GB
  • SATA SED (7200 rpm):
    Up to: 320GB
  • 3.5-inch Removable SATA (7200 rpm):
    Up to: 500GB
Optical drives:
  • SATA Blu-ray writer
  • SATA SuperMulti LightScribe DVD writer
  • SATA DVD-ROM
Ports
  • 10 USB 2.0
  • 1 serial (optional)
  • 1 parallel (optional)
  • 1 eSATA (optional)
  • 1 DisplayPort
  • 1 VGA video
  • 1 PS/2 keyboard
  • 1 PS/2 mouse
  • 1 RJ-45
  • 1 microphone/headphone jack
  • 1 line in
  • 1 line out
  • DVI output available via optional DisplayPort to DVI adapter
Slots
  • 1 low-profile PCI
  • 1 low-profile PCIe x1
  • 2 low-profile PCIe x16
Audio
Realtek ALC261 high definition audio codec (all ports are stereo)
  • Integrated Intel 82579LM Gigabit Ethernet
  • Intel Pro 1000 CT Gigabit
  • 802.11 b/g/n wireless
1. Use of HP System Software Recovery Disks (SSRD) is not supported on 80GB or 128GB SSD models due to minimum image size requirements (>=140GB) for the SSRD.
Electrical specifications
Feature
Standard efficiency
240 W active PFC
High efficiency1
240 W active PFC 87%/90%/87% efficient at 20%/50%/100% load
Operating voltage range
90 - 264 V ac
Rated voltage range
100 - 240 V ac
Rated line frequency
50/60 Hz
Operating line frequency range
47 - 63 Hz
Rated input current
4 A
Rated input current with Energy Efficient1 power supply
4 A
Current leakage (NFPA 99)
<275 µA
1: High efficiency power supply is a requirement for ENERGY STAR qualification in conjunction with a select range of processors and modules.
Physical specifications
Feature
Chassis (H x W x D)
100 x 338 x 379 mm (4.0 x 13.3 x 14.9 in)
System volume
13.0 L (790.3 cu in)
Tower stand (H x W x D)
29 x 178 x 200 mm (1.1 x 7.0 x 7.9 in)
Packaging (H x W x D)
229 x 500 x 594 mm (9.0 x 19.7 x 23.4 in)
System weight
7.6 kg (16.7 lb)
Shipping weight
8.1 kg (17.9 lb)
Max supported weight (desktop orientation)
35.0 kg (77.0 lb)
Software/OS
Feature
  • Genuine Windows 7 Professional 32-bit
  • FreeDOS
  • Genuine Windows 7 Professional 64-bit
  • Genuine Windows 7 Ultimate 32-bit
  • Genuine Windows 7 Ultimate 64-bit
  • Genuine Windows 7 Home Premium 32-bit
  • Genuine Windows 7 Home Premium 64-bit
  • Genuine Windows 7 Home Basic 32-bit
  • Genuine Windows Vista Business 32-bit
  • Genuine Windows Vista Home Basic 32-bit
Software installed
  • HP ProtectTools Security Suite
  • HP Software Management Agent
  • Computrace for Desktops Agent
  • HP Vision Diagnostics
  • PDF Complete Corporate Edition
  • Microsoft Office trial version
Environmental specifications
Feature
Temperature range
  • Operating:
    10° to 35°C ( 50° to 95°F)
  • Non-operating:
    -30° to 60°C (-22° to 140°F)
Relative humidity
  • Operating:
    10% to 90% (non-condensing at ambient)
  • Non-operating:
    5% to 95% (non-condensing at ambient)
 Maximum altitude   (unpressurized)
  • Operating:
    3048 m (10,000 ft)
  • Non-operating:
    9144 m ( 30,000 ft)
Safety certifications
Feature
Hardware certifications
  • FCC
  • B
  • CE
  • TUV- cTUVus Mark Canada and United States
  • TUV- GS Mark for European Union
Security
  • IEEE and WiFi compliant 64/128 bit WEP encryption
  • AES: CCM
  • 802.1x authentication
  • WPA: 802.1x.
  • WPA-PSK and TKIP WPA2 certification
  • IEEE 802.11i
  • Cisco Certified Extensions, all versions through V5
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
