HP Compaq 8200 Elite Ultra-slim PC - Specifications
System specifications
Feature
Processor
  • Intel Core i7-2600S (2.80 GHz, 8MB cache, 4 cores)
  • Intel Core i5-2500S (2.70 GHz, 6MB cache, 4 cores)
  • Intel Core i5-2400S (2.50 GHz, 6MB cache, 4 cores)
  • Intel Core i3-2120 (3.30 GHz, 3MB cache, 2 cores)
  • Intel Core i3-2100 (3.10 GHz, 3MB cache, 2 cores)
Intel Q67 Express
Memory slots
2 DIMM
Memory, maximum
8GB 1333 MHz DDR3 SDRAM
Storage
Internal drive bays:
One 2.5 in
Internal drives:
  • SATA (7200 rpm):
    Up to: 300GB
  • SATA Solid State Drive (SSD):
    Up to: 160GB
  • SATA SED (7200 rpm):
    Up to: 320GB
Optical drives:
  • SATA Blu-ray writer
  • SATA SuperMulti LightScribe DVD writer
  • SATA DVD-ROM
Graphics
  • Integrated Intel HD 2000/3000
  • ATI Radeon HD 5450 (512MB)
  • HP DisplayPort to DVI-D adapter
  • HP DisplayPort to HDMI adapter
  • HP DisplayPort to VGA adapter
Ports
  • 10 USB 2.0
  • 1 DisplayPort
  • 1 VGA video
  • 1 PS/2 keyboard
  • 1 PS/2 mouse
  • 1 RJ-45
  • 1 microphone/headphone jack
  • 1 line in
  • 1 line out
  • DVI output available via optional DisplayPort to DVI adapter
Slots
  • 1 mini PCIe
  • 1 MXM
Audio
Realtek ALC261 high definition audio codec (all ports are stereo)
  • Integrated Intel 82579LM Gigabit Ethernet
  • Intel Centrino Advanced N 6205 wireless
Physical specifications
Feature
Chassis (H x W x D)
66 x 252 x 254 mm (2.6 x 9.9 x 10 in)
System volume
4.2 L ( 257.5 cu in)
Tower stand (H x W x D)
27 x 125 x 170 mm (1.1 x 4.9 x 6.7 in)
Packaging (H x W x D)
218 x 398 x 500 mm (8.6 x 15.7 x 19.7 in)
System weight
3.1 kg (6.8 lb)
Shipping weight
6.5 kg (14.4 lb)
Max supported weight (desktop orientation)
35.0 kg (77.0 lb)
Electrical specifications
Feature
High efficiency1
Integrated graphics:
135 W active PFC 87% efficient
Discrete graphics:
180 W active PFC 87% efficient
Operating voltage range
90 - 264 V ac
Rated voltage range
100 - 240 V ac
Rated line frequency
50/60 Hz
Operating line frequency range
47 - 63 Hz
Rated input current with Energy Efficient1 power supply
  • 135 W: 2.4 A
  • 180 W: 2.9 A
Current leakage (NFPA 99)
<275 µA
1: High efficiency power supply is a requirement for ENERGY STAR qualification in conjunction with a select range of processors and modules.
Environmental specifications
Feature
Temperature range
  • Operating:
    10° to 35°C ( 50° to 95°F)
  • Non-operating:
    -30° to 60°C (-22° to 140°F)
Relative humidity
  • Operating:
    10% to 90% (non-condensing at ambient)
  • Non-operating:
    5% to 95% (non-condensing at ambient)
 Maximum altitude   (unpressurized)
  • Operating:
    3048 m (10,000 ft)
  • Non-operating:
    9144 m ( 30,000 ft)
Safety certifications
Feature
Hardware certifications
  • FCC
  • B
  • CE
  • TUV- cTUVus Mark Canada and United States
  • TUV- GS Mark for European Union
Security
  • IEEE and WiFi compliant 64/128 bit WEP encryption
  • AES: CCM
  • 802.1x authentication
  • WPA: 802.1x.
  • WPA-PSK and TKIP WPA2 certification
  • IEEE 802.11i
  • Cisco Certified Extensions, all versions through V5
