HP Omni Pro 110 Business PC - Overview
Product description
HP Omni Pro 110 Business PC has an integrated All-in-One form factor with 20-inch diagonal widescreen HD anti-glare display and Intel Core 2 Duo, Pentium, or Celeron processor.
Product features
Feature
Processors1
Intel Celeron Dual-Core processors:
Intel Celeron E3400 processor (2.6 GHz, 1MB L2 cache, 800-MHz FSB)
Intel Pentium Dual-Core processors:
  • Intel Pentium E5800 processor (3.20 GHz, 2MB L2 cache, 800-MHz FSB)
  • Intel Pentium E6700 processor (3.20 GHz, 2MB L2 cache, 1066-MHz FSB)
Intel Core 2 Duo processors:
  • Intel Core 2 Duo E7500 processor (2.93 GHz, 3 MB L2 cache, 1066-MHz FSB)
  • Intel Core 2 Duo E7600 processor (3.06 GHz, 3 MB L2 cache, 1066-MHz FSB)
  • Intel Core 2 Duo E8400 processor (3.0 GHz, 6 MB L2 cache, 1333-MHz FSB)
Intel G41 Express chipset
Graphics
  • Integrated Intel Graphics Media Accelerator X4500
  • Shared system memory
  • DirectX 10 capable
20-inch diagonal widescreen HD CCFL anti-glare display
Resolution: 1600 x 900 resolution (16:9)
Contrast ratio: 1000:1 typical
Image brightness: 250 nits typical
Refresh rate: 5 ms
Viewing angle (typical): Up to 160° horizontal/160° vertical (10:1 minimum contract ratio)
Memory2
Standard:
  • PC3-10600 DDR3 1333-MHz non-ECC SDRAM
  • Two 200-pin SODIMM slots supporting dual channel memory
  • 1GB (1GB x 1) - for Linux and FreeDOS only
  • 2GB (2GB x 1)
  • 3GB (2GB + 1GB)
  • 4GB (2GB x 2)
Dual-channel:
Maximized dual-channel performance requires SODIMMs of the same size and speed in both memory slots.
Communications3
Realtek RTL8111E Gigabit Ethernet:
Integrated 10/100/1000 NIC
HP 802.11 PCIe minicard wireless module (optional):
  • Support for 802.11 b, g, and n
  • Up to 300 mb/s data rate Built-in antennas (1 transmit, 1 receive)
Storage
Hard drive:
  • 3.5-inch, 7200 rpm, 3.0 Gb/s, Smart IV SATA hard drive
  • 250GB
  • 500GB
  • 750GB
  • 1TB
Slim optical drive:
  • Tray-load SuperMulti DVD LightScribe burner
  • Read: 8x max DVD-ROM
  • 24x max CD-ROM
  • Write: 8x max DVD±R
  • 6x max DVD±R DL
  • 8x max DVD+RW
  • 6x max DVD-RW
  • 5x max DVD-RAM
  • 24x max CD-R
  • 24x max CD-RW
Interfaces
  • 6-in-1 media card reader - Supports Secure Digital (SD, SDHC), MultiMedia Card (MMC), xD-Picture Card, Memory Stick, Memory Stick Pro
  • USB 2.0 - Six (2 left side, 4 rear)
  • Microphone jack - One
  • Stereo audio headphone jack - One
  • Stereo audio line out -One
  • Power connector - One
  • RJ-45/Ethernet - One
Power supply
  • External 150-watt energy efficient power supply
  • 87% efficiency
  • Active PFC
1: Intel's numbering is not a measurement of higher performance. Processor numbers differentiate features within each processor family, not across different processor families.
2: Full availability of 4GB or more of memory requires a 64-bit operating system. With Windows 32-bit operating systems, the amount of usable memory is dependent upon your configuration, so that above 3GB all memory may not be available due to system resource requirements.
3: The term "10/100/1000" or "Gigabit" Ethernet indicates compliance with IEEE standard 802.3ab for Gigabit Ethernet, and does not connote actual operating speed of 1 Gb/s. For high-speed transmission, connection to a Gigabit Ethernet server and network infrastructure is required.
Software Overview
Feature
Operating system1
  • Genuine Windows 7 Professional Edition 642
  • Genuine Windows 7 Professional Edition 322
  • Genuine Windows 7 Home Basic Edition 642
  • Windows 7 Starter Edition 32
  • RedFlag Linux3
  • FreeDOS
Preinstalled software (varies by country)
  • HP Power Assistant (pre-loaded)
  • HP Support Assistant
  • HP Vision Diagnostics
  • Cyberlink YouCam BE
  • Cyberlink PowerDVD
  • Cyberlink Power2Go
  • PDF Complete
  • Norton Internet Security4
1: Windows XP Mode, included in Windows 7 Professional Edition 32, works with virtualization software such as Windows Virtual PC to run older Windows XP business software on the Windows 7 desktop.
2: System may require upgraded and/or separately purchased hardware and/or a DVD drive to install the Windows 7 software and take full advantage of Windows 7 functionality. Click here for more details.
The above-mentioned web link will take to a non-HP Web site. HP does not control and is not responsible for information outside of the HP Web site.
3: The following features are not supported by RedFlag Linux and FreeDOS: display's brightness control buttons on chassis.
4: 60 day trial period for Norton Internet Security. Internet access required to receive updates. First update included. Subscription required for updates thereafter.
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
