HP LE1851wt 18.5-inch Widescreen LCD Monitor - Overview
Product description
Product features
Feature
Model
LG142AA
Type
18.5-inch diagonal widescreen Thin-Film Transistor LCD active matrix (16:9 aspect ratio)
47 cm (18.5 in) widescreen
Screen opening (W x H)
40.9 x 23 cm (16.1 x 9.05 in)
Panel type
TN
Aspect ratio
16:9
Viewing angle (typical)1
Up to 160° horizontal/160° vertical (10:1 minimum contrast ratio)
Brightness (typical)1
250 nits (cd/m2)
Contrast ratio (typical)1
1000:1
Response time (typical)1
5 ms (On/Off)
Pixel pitch
0.03 cm
Backlight lamp life (to half brightness)
40,000 hours
Color gamut
72%
1: All performance specifications represent the typical specifications provided by HP's component manufacturers; actual performance may vary either higher or lower.
