Document ID: c02738231
Version: 1
HP EliteBook 8740w Mobile Workstation System BIOS Update F.0B
Release date : 01-Mar-2011
Last updated : 02-Mar-2011
DETAILS OF CHANGE
New features:
  • The warning message that displays during system startup (after the HP Logo displays), about how the notebook does not have a wireless LAN (WLAN) card installed, has been removed.
Field issue fixes:
  • Improved the BIOS flashing algorithm to minimize a BIOS corruption issue.
  • Fixed an issue where the the BIOSConfig utility could not change the "Virtualization Technology" field in F10 Setup.
  • Fixed an issue where an external mouse or external keyboard would not work in the PointSec Preboot Environment.
  • Fixed an issue where the battery check utility reports an incorrect battery warranty period.
  • Fixed an issue where the computer could not boot with Boot Star Boot Manager. Note: This issue only occurs with Microsoft Windows XP SP3.
REASON FOR CHANGE
To implement changes under "Details of Change."
IMPACT OF CHANGE
None.
Components affected:
DATE OF CHANGE
Effective date : 04-Apr-2011
Hardware platforms affected : HP EliteBook 8740w Mobile Workstation
