To view a video demonstrating the procedure for removing the part click here to access the Services Media Library (www.hp.com/go/sml). Select Printers and Multifunction under the Product category, select HP Color LaserJet Printers under the Product family, and then select the printer model under the product series category.
Transfer roller replacement
Turn the power off.
Open the top cover and remove the print cartridge.
Do not touch the black rubber on the transfer roller. Skin oils on the roller can cause print-quality problems. Use disposable gloves when you remove the transfer roller. -
Use a flat-blade screwdriver to lift the left end of the metal shaft out of place (near the blue gear). Slide the transfer roller to the left to remove it.
Remove the new transfer roller from its protective bag.
Align the transfer roller with the slots in the product and push until it clicks into place.
Make sure that the black collar on the left side is oriented correctly, with the open end face-down (the solid end is face-up). -
Install the print cartridge and close the top cover.
Turn the power on.
