HP LaserJet M4345 Multifunction Printer Series - Replace the Print Cartridge
To view a video demonstrating the procedure for removing the part click here to access the Services Media Library (www.hp.com/go/sml). Select Printers and Multifunction under the Product category, select HP Color LaserJet Printers under the Product family, and then select the printer model under the product series category.
Print cartridge removal
  1. Pull the top-cover release to open the top cover.
  2. Grasp the print cartridge by the handle, and remove it from the device.
  3. Remove the new print cartridge from the packaging.
  4. Remove any protective tape from the print cartridge.
  5. Insert the new print cartridge in the device, and close the top cover.
Parts return
