This document applies to HP Touch 610 and 620 all-in-one desktop computers.
caution:This product contains components that can be damaged by electrostatic discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, use a static dissipative work surface (such as a conductive foam pad), and wear an ESD wrist strap connected to a grounded surface.
warning:Make sure the computer is disconnected from power before starting.
Step 1
Squeeze the release tabs for the rear I/O door.
Step 2
Swing out the rear I/O door until it locks into position.
Step 3
Pull on the top edge of the USB dongle cap to remove it from the computer.
Step 1
Find the two tabs on the bottom of the USB dongle cap.
Step 2
Find the slots on the rear cover.
Step 3
Align the two tabs onto their slots and press the cover into place.
Step 4
Swing in the rear I/O door until it locks into position.
Step 1
Remove the USB dongle cap.
Step 2
Pull off the screw cover at the top edge of the cap.
Step 3
Remove the screw.
Step 4
Slide the right rear cap towards the middle of the computer.
Step 5
Pull off the cap.
Step 1
Find the tab on the top side of the right rear cap.
...that slides under the screw hole on the rear cover.
Step 2
Find the tabs on the top edges ...
...and the bottom edges of the cap.
that slide into slots on the upper edge of the rear cover...
...and the lower edge of the rear cover.
Step 3
Slide the screw tab on the door under the hole on the frame.
Step 4
Press the right rear cap down against the rear cover so the tabs align into their slots.
Step 5
Slide the cap towards the side...
... until the screw hole on the cap and the rear cover align.
Step 6
Replace the screw.
Step 7
The screw cover has two small tabs...
...that fit into slots on the rear cover.
Step 8
Press the screw cover tabs into the slots and snap the screw cover into place.
Step 9
Replace the USB dongle cap.
Step 1
Step 2
Remove the right rear cap.
Step 3
Detach the two screws for the right side cap.
Step 4
Use a flat head screwdriver to pry up the latch securing the cap to the rear cover.
Step 5
Rotate the cap off of the unit.
Step 1
Find the slotted tabs...
...that fit into slots on the front bezel.
Step 2
Find the latch on the right side cap...
... that attaches over a slot on the rear cover.
Step 3
Align the slotted tabs over the slots on the bezel.
Step 4
Rotate the cap and press until the latch snaps into place.
Step 5
Press the cap edges to make sure it is correctly in place.
Step 6
Replace the two screws for the right side cap.
Step 7
Replace the right side cap and the USB dongle cap.
Step 1
Step 2
Step 3
Remove the screw.
Step 4
Slide the left rear cap towards the middle of the computer.
Step 5
Pull off the cap.
Step 1
Find the tab on the top side of the left rear cap.
Step 2
Step 3
Step 4
Press the left rear cap down against the rear cover so the tabs align into their slots.
Step 5
Step 6
Replace the screw.
Step 7
Step 8
Step 9
