This document applies to HP Touch 610 and 620 all-in-one desktop computers.
Use the steps in this document to help replace a hard drive in your computer. If you want to add a hard drive with more capacity (upgrade), know that you can upgrade to any sized hard drive that meets the connection type in your computer. Most often this is serial ATA (SATA or eSATA). Also know that there are formatting limitations that may be encountered for drives larger than 2 TB. To access all the data on drives larger than 2 TB format the drive using GPT or create multiple partitions smaller than 2 TB.
