HP Compaq 4000 Pro Small Form Factor Business PC Product Specifications
Product description
A stable, reliable personal computer is an absolute necessity in every business environment, big and small. Required to perform every day, the HP Compaq 4000 Pro includes proven PC modules and components designed to rigorous business PC standards.
Product features
Feature
Intel B43 Express with Intel GMA 4500 Graphics
Processor
Intel Celeron Processors:
  • Intel Celeron E3400 Processor (2.60 GHz, 1M L2 cache, 800 MHz FSB)
  • Intel Celeron E3500 Processor (2.70 GHz, 1M L2 cache, 800 MHz FSB)
Intel Pentium Processors:
  • Intel Pentium E5800 Processor (2.80 GHz, 2M L2 cache, 800 MHz FSB)
  • Intel Pentium E6700 Processor (3.20 GHz, 2M L2 cache, 1066 MHz FSB)
  • Intel Pentium E6800 Processor (3.33 GHz, 2M L2 cache, 1066 MHz FSB)
Intel Core 2 Duo Processors:
  • Intel Core 2 Duo E7500 Processor (2.93 GHz, 3M L2 cache, 1066 MHz FSB)
  • Intel Core 2 Duo E7600 Processor (3.06 GHz, 3M L2 cache, 1066 MHz FSB)
  • Intel Core 2 Duo E8400 Processor (3.0 GHz, 6M L2 cache, 1333 MHz FSB)
  • Intel Core 2 Duo E8500 Processor (3.16 GHz, 6M L2 cache, 1333 MHz FSB)
  • Intel Core 2 Duo E8600 Processor (3.33 GHz, 6M L2 cache, 1333 MHz FSB)
Intel Core 2 Quad Processors:
  • Intel Core 2 Quad Q9505s Processor (2.83 GHz, 6M L2 cache, 1333 MHz FSB, 65 W TDP)
  • Intel Core 2 Quad Q9550s Processor (2.83 GHz, 12M L2 cache, 1333 MHz FSB, 65 W TDP)
Maximum memory
Supports up to 8GB of DDR3 SDRAM using DIMM modules.
Video graphics
  • Intel Graphics Media Accelerator 4500 (integrated)
  • NVIDIA NVS 300 512MB graphics card
  • ATI Radeon HD 4550 512MB graphics card
Hard disk drives
  • HP 250GB hard disk drive (7,200 rpm, NCQ, Smart IV)
  • HP 320GB hard disk drive (7,200 rpm, NCQ, Smart IV)
  • HP 500GB hard disk drive (7,200 rpm, NCQ, Smart IV)
  • HP 1TB hard disk drive (7,200 rpm, NCQ, Smart IV)
Optical disc drives
  • HP DVD-ROM drive
  • HP SuperMulti LightScribe writer drive
  • HP Blu-ray writer drive
Media card readers
HP Media Card Reader (22-in-1)
Network interface connections
  • Intel 82567V GbE Network Connection (integrated)
  • HP 802.11 b/g/n Wireless NIC (PCIe x1 card)
Multi-Media1
  • High Definition Audio with Realtek ALC261 codec (all ports are stereo)
  • Microphone/Headphone front ports (standard)
  • Line-out and Line-in rear ports (standard)
  • Multi-streaming capable (standard)
  • Internal speaker (standard)
  • HP Thin USB powered speakers (optional)
Input/Output devices
  • HP PS/2 standard keyboard
  • HP USB standard keyboard
  • HP USB smart card (CCID) keyboard
  • HP USB Mini keyboard
  • HP USB and PS/2 washable keyboard
  • HP PS/2 optical mouse
  • HP USB optical mouse
  • HP USB laser mouse
  • HP USB and PS/2 washable mouse
Miscellaneous devices and configurations
  • Serial port adapter (RS-232 compatible)
  • Parallel port adapter
  • PC tower stand
  • Non-standard HDD disk partitioning (50%/50%)
1: The audio ports/jacks provided by all of our systems are 3.5 mm in diameter. This would include both the front jacks and rear jacks, for audio in/out, mic in and headphone out.
System specifications
Feature
I/O ports
USB 2.0
  • Front – four (4) ports
  • Rear – four (4) ports
Serial
One RS-232 compatible port standard second port available optionally
Parallel
One port available as an option
PS/2
Color coded support for keyboard (purple) and mouse (green)
Video
VGA and DVI-D provide integrated dual independent monitor support
Audio
  • Front – microphone & headphone
  • Rear – Line-In & Line-Out
NIC
RJ-45 port accesses the integrated Intel network interface controller
Slots
Type and quantity
  • (2) PCI
  • (1) PCIe x1; 10 W max power
  • (1) PCIe x16; 25 W max power
Slot specifications
  • Low profile: 2.5-inch
  • Length: 6.6-inch
  • 25 W maximum
Bays
3.5-inch external
1 bay available for optional Media Card Reader
5.25-inch external
1 bay – 8.19-inch depth for optional optical disc drive
Internal HDD Bay
1 bay for 3.5-inch hard disk drive
Controller
Hard Drive Controller
  • Serial ATA (SATA) 2.0
  • Supports up to 3.0 GB/s
SATA Interfaces
(2) total
Host SATA Controller
Advanced Host Controller Interface (AHCI) Revision 1.2. The specification includes a description of the hardware/software interface between system software and the host controller hardware.
Environmental specifications
Feature
Temperature range1
  • Operating: 10° to 35°C (50° to 95°F)
  • Non-operating: -30° to 60°C (-22° to 140°F)
Relative humidity
  • Operating: 10% to 90% (non-condensing at ambient)
  • Non-operating: 5% to 95% (non-condensing at ambient)
Maximum altitude (unpressurized)
  • Operating: 3048 m (10,000 ft)
  • Non-operating: 9144 m (30,000 ft)
1: Operating temperature is de-rated 1.0°C per 300 m (1000 ft) to 3000 m (10,000 ft) above sea level, no direct sustained sunlight. Maximum rate of change is 10°C/Hr. The upper limit may be limited by the type and number of options installed.
Electrical specifications
Feature
Max power rating
240 W
Power Factor Correcting (PFC)
Active
Maximum voltage range
  • Standard: 90 to 140 V ac
  • High efficiency: 180 to 264 V ac
Nominal voltage range
  • Standard: 100 to 127 V ac
  • High efficiency: 200 to 240 V ac
Rated line frequency
50/60 Hz
Operating line frequency range
47 to 63 Hz
Rated input current
4 A
Maximum allowable leakage current
275 µA
Power supply fan
92 mm variable speed
Audio
High definition audio
Feature
Type
Integrated
High Definition Stereo Codec
Realtek 2-channel ALC261 codec
Audio I/O ports1
  • Front microphone-In (150K ohm Input Impedance)
  • Rear Line-In (150K ohm Input Impedance)
  • Rear Line-Out (190 ohms Output Impedance, expects at least a 10K ohm load)
  • Front Headphone-Out (0.5 Ohm Output Impedance, expects at least a 32 ohm load)
Multistreaming Capable
Multistreaming can be enabled in the Realtek control panel to allow independent audio streams to be sent to/from the front and rear jacks.
Sampling
8 kHz to 192 kHz
Wavetable Syntheses (software)
Yes – uses OS soft wavetable
Analog audio
Yes
Number of Channels on Line-Out (mono/stereo)
Stereo (Left & Right channels)
Internal audio speaker power rating
1.5 W
Internal speaker
Yes
External speaker jack (Line-Out)
Yes
1: Front Headphone-Out (0.5 Ohm Output Impedance, expects at least a 32 ohm load) Internal Speaker Amplifier is for the internal speaker only. External speakers need to be powered externally. Rear Line-In audio port is re-task able as Line-In or Microphone-In.
Feature
On/Off/Volume
Controls Right side of right speaker
Power LED
Front of right speaker (green)
Frequency response
FO to 20 kHz
Watts
2/3 W (normal/maximum)
Dimensions/Speaker (H x W x D)
14.52 x 9.50 x 2.45 cm (5.72 x 3.74 x 0.96 in)
Net weight
0.31 kg (0.68 lbs)
Color
Black
Environmental (all conditions non-condensing)
  • Operating temperature: -10° to 40°C (14° to 104°F)
  • Relative humidity: 40% to 90%
Speaker cable length
  • Input cord: 180 cm (5.91 ft)
  • L-channel cord: 100 cm (3.28 ft)
  • USB cord: 180 cm (5.91 ft)
Communications
Feature
Connector
RJ-45
Controller
Intel 82567V Gigabit platform LAN Connect Networking Controller
Memory
24KB FIFO packet buffer memory
Data rates supported
10/100/1000 Mb/s
Compliance
IEEE 802.3, 802.3ab and 802.3u compliant
Bus architecture
GLCI, LCI interface. Intel specific MAC to PHY interface
Data transfer mode
At gigabit GLCI (Intel proprietary 802.3 series-based interface) is for Data, LCI (parallel bus) for MDIO, at 10/100 LCI for both data and MDIO, GLCI is idle.
10/100/1000 Mb/s
Hardware certifications
  • FCC B
  • CE
  • TUV-cTUVus Mark Canada and United States
  • TUV-GS Mark for European Union
Power requirement
Requires 3.3 V, 1.9/1.8 V and 1.0 V or just 3.3 V with integrated regulators. Power consumption 1.3 W for 82567 whole LOM
Boot ROM support
Yes
Network transfer mode
  • Full-duplex
  • Half-duplex (not supported for the 1000BASE-T transceiver)
Network transfer rate
  • 10BASE-T (half-duplex) 10 Mb/s
  • 10BASE-T (full-duplex) 20 Mb/s
  • 100BASE-TX (half-duplex) 100 Mb/s
  • 100BASE-TX (full-duplex) 200 Mb/s
  • 1000BASE-T (full-duplex) 2000 Mb/s
Environmental
  • Operating temperature: 0° to 55°C (32° to 131°F) to 70°C (158°F) for external regulator
  • Operating humidity: 85% at 55°C (131°F)
Management
  • WOL
  • Auto MDI crossover
  • PXE
  • Multi-port teaming
  • RSS
  • Advanced cable diagnostic
HP Wireless Network Connection 802.11 b/g/n
Feature
Dimensions (L x H)
8.5 x 12 cm (3.3 x 4.7 in)
40 g (0.08 lbs)
Controller
Ralink RT2790
System interface
PCIExpress x1
Network standard
802.11 b/g/n
Frequency band
2.400 to 2.497 GHz
Operating: -10° to 65°C (14° to 149°F)
Storage temperature
Non-operating: -40° to 80°C (-40° to 176°F)
Humidity
  • Operating: 10 to 90%
  • Non-operating: 5 to 95%
Operating voltage
  • 3.3 V +/- 9%
  • 12 V +/- 8%
Certifications
Wi-Fi certified
Certifications for use by country
  • United States
  • Canada
  • Peru
  • Taiwan
Security
  • IEEE and WiFi compliant 64/128 bit WEP encryption
  • AES: CCM
  • 802.1x authentication
  • WPA: 802.1x. WPA-PSK and TKIP
  • WPA2 certification
  • IEEE 802.11i
  • Cisco Certified Extensions, all versions through V5
Graphics
Intel Graphics Media Accelerator (GMA) 4500
Feature
3D/2D Controller
Microsoft DirectX 10 based with support for Pixel Shader 3.0
VGA Controller
Integrated
DisplayPort
  • Integrated
  • Multimode capable
  • Supports HDCP
Bus type
PCI Express x16
RAMDAC integrated
350 MHz
HW video decode
Hardware Accelerated decode for MPEG2 encrypted video; support for PAVP Lite (default)
Maximum color depth
32 bits/pixel
Maximum vertical refresh rate
85 Hz at up to 1920 x 1440, 75 Hz at 2048 x 1536. Varies with mode and configuration.
Multi-display support
Integrated dual independent monitor support facilitated via one VGA and one single link DVI-D port integrated on the back plane of the system board and presented as part of the rear I/O set of interfaces.
Graphics/Video API support
  • Microsoft DirectX 10
  • OpenGL 1.5 (OpenGL 2.0 available in a driver update)
ATI Radeon HD 4550 (512MB DH) PCIe x16 graphics card
Feature
Bus type
PCI Express x16
85 Hz
Display support Integrated
400 MHz RAMDAC
Display max resolution
  • 1900 x 1200 digital
  • 2048 x 1536 analog
Board display options
Supports two displays via included DMS-59 to dual VGA cable or 2 DVI monitors via optional DMS-59 to dual DVI cable kit part number: DL139A. 4-pin mini-DIN S-video connector for TV output.
Board configuration
  • Graphics Chip: RV710
  • Core clock: 600 MHz
  • Memory clock: 800 MHz
  • Frame buffer: 512MB DDR3, 64 bit wide
Languages supported
24 languages:
  • English
  • Arabic
  • Chinese Simplified
  • Chinese Traditional
  • Czechoslovakian
  • Danish
  • Dutch
  • Finnish
  • French
  • German
  • Greek
  • Hebrew
  • Hungarian
  • Italian
  • Japanese
  • Korean
  • Norwegian
  • Polish
  • Portuguese
  • Russian
  • Spanish
  • Swedish
  • Thai
  • Turkish
Hard drives
HP 250GB 3.5-inch hard disk drive
Feature
Capacity
250,059,350,016 bytes
Rotational speed
7,200 rpm
Interface
Serial ATA (SATA)
Synchronous transfer rate (maximum)
Up to 3 GB/s (limited by the system SATA controller)
Buffer size
8MB
Logical blocks
488,397,168
Seek time (typical reads, includes controller overhead, including settling)
  • Single track: 1.0 ms
  • Average: 8.5 ms
  • Full-stroke: 18 ms
Height (nominal)
2.54 cm (1 in)
Width (nominal)
  • Media diameter: 8.89 cm (3.5 in)
  • Physical size: 10.2 cm (4 in)
5° to 55°C (41° to 131°F)
HP USB Standard keyboard
Feature
Physical characteristics
  • Keys: 104, 105, 106, 107, 109 layout (depending upon country)
  • Dimensions (L x W x H): 45.8 x 16.3 x 2.5 cm (18.0 x 6.4 x 0.98 in)
  • Weight: 0.9 kg (2 lb)
Electrical
  • Operating voltage: + 5 V dc ± 5%
  • Power consumption: 50 mA maximum (with three LEDs On)
  • System interface: USB Type A plug connector
  • ESD: CE level 4, 15 kV air discharge
  • EMI – RFI: Conforms to FCC rules for a Class B computing device
  • Microsoft PC 99 – 2001: Functionally compliant
Mechanical
  • Languages: 38 available
  • Keycaps: Low-profile design
  • Switch actuation: 55 g nominal peak force with tactile feedback
  • Switch life: 20 million keystrokes (using Hasco modified tester)
  • Switch type: Contamination-resistant switch membrane
  • Key-leveling mechanisms: For all double-wide and greater-length keys.
  • Cable length: 1.8 m (6 ft)
  • Microsoft PC 99 –2001: Mechanically compliant
  • Acoustics: 43 dBA maximum sound pressure level
Environmental
  • Operating temperature: 10° to 50°C (50° to 122°F)
  • Non-operating temperature: -30° to 60°C (-22° to 140°F)
  • Operating humidity: 10% to 90% (non-condensing at ambient)
  • Non-operating humidity: 20% to 80% (non-condensing at ambient)
  • Operating shock: 40 g, six surfaces
  • Non-operating shock: 80 g, six surfaces
  • Operating vibration: 2 g peak acceleration
  • Non-operating vibration: 4 g peak acceleration
  • Drop (out of box): 66 cm (26 in) on carpet, six-drop sequence
  • Drop (in box): 107 cm (42 in) on concrete, 16-drop sequence
Approvals
  • UL
  • CSA
  • FCC
  • CE Mark
  • TUV
  • TUV-GS
  • VCCI
  • BSMI
  • C-Tick
  • MIC
Ergonomic compliance
  • ANSI HFS 100
  • ISO 9241-4
  • TUV-GS
Kit contents
  • Keyboard
  • Installation guide
  • Warranty card
  • Safety and comfort guide
Feature
Electrical
  • System interface: PS/2 6-pin mini din connector
Mechanical
  • Microsoft PC 99 - 2001: Mechanically compliant
Environmental
Approvals
  • UL
  • CSA
  • FCC
  • CE Mark
  • TUV
  • TUV-GS
  • VCCI
  • BSMI
  • C-Tick
  • MIC
  • ANSI HFS 100
  • ISO 9241-4
  • TUV-GS
Kit contents
  • Keyboard
  • Warranty card
HP USB Smart Card (CCID) keyboard
Feature
  • Form factor: USB basic smart card keyboard
  • Colors: Carbonite/Silver
  • Dimensions (L x W x H): 46.3 x 16.1 x 3.3 cm (18.2 x 6.3 x 1.3 in)
  • Weight: 0.9 kg (2 lb) minimum
Electrical
  • Power consumption: 100 mA maximum (with three LEDs On)
  • Microsoft PC 99 - 2001: Functionally compliant
Mechanical
  • Languages: 30+ available
  • Keycaps: Standard design
Environmental
SmartCard function
  • Support: All ISO 7816 smart cards
  • Interface: Reads from and writes to all ISO7816-1, 2, 3, 4 memory and microprocessor smart cards (T=0, T=1)
  • Chipset: SCM STCIII
  • Standard APIs supported: PC/SC, EMV2000, CT-API
  • Power:
    • USB Port
    • Short circuit detection (protects smart card and reader)
    • Power supply compliant with ISO7816 and EMV (5 V, 60 mA)
    • Supports 3 V and 5 V cards
  • Power consumption: 100 mA maximum draw
  • Communication:
    • From card: 9600 b/s to 330,000 b/s
    • From computer: 12 Mb/s (USB transfer speed)
  • Landing mechanism:
    • Contact device: Friction contact
    • Card insertions rating: Up to 100,000 insertion cycles
  • Interface modes: CCID protocol
  • Reader performance interface: USB connection
  • Electro-magnetic standards:
    • Europe: 2004/108/EC
    • USA: USAFCC part 15
Approvals
  • CE-Mark
  • UL
  • CSA
  • FCC
  • CE Mark
  • TUV
  • TUV-GS
  • VCCI
  • BSMI
  • C-Tick
  • MIC
  • EMV2000
  • USB-IF
  • ISO 9241-4
  • TUV-GS
Kit contents
  • Keyboard
  • I/O Security and Documentation CD
  • Warranty card
HP USB/PS2 washable keyboard
Feature
Compatibility
The HP USB/PS2 Washable Keyboard is compatible with all HP Compaq Business PCs.
  • Keys: 104 (US) layout or 105 (EU) layout (depending upon country)
  • Dimensions (L x W x H): 44.9 x 16.8 x 3.5 cm (17.67 x 6.62 x 1.38 in)
0.77 kg (1.7 lb) minimum
Electrical
  • EMI - RFI: Conforms to FCC rules for a Class B computing device
Mechanical
  • Keycaps: Stepped profile design
  • Cable length: 2.2 m (7 ft)
Environmental
  • Non-operating humidity: 0% to 95% (non-condensing at ambient)
Approvals
  • UL
  • cUL
  • FCC
  • CE
  • TUV-GS
  • VCCI
  • BSMI
  • C-Tick
  • KCC
  • USB-IF
  • WHQL
  • EN/IEC 60601-1
  • IP66/NEMA4X
  • ANSI HFS 100
  • ISO 9241-4
  • TUV-GS
Kit contents
  • Keyboard with USB cable
  • USB to PS2 adapter
  • Quick disconnect cable with extension to lengthen the cable
  • I/O Security Software & Documentation CD including the safety and comfort guide
  • Warranty card
Feature
Dimensions (H x L x W)
3.95 x 6.21 x 11.7 cm (1.56 x 2.44 x 4.61 in)
126 g (4.44 oz)
Electrical
  • System interface: PS/2 mini-din connector
Environmental
  • Operating temperature: 0° to 40°C (-32° to 104°F)
  • Non-operating temperature: -20° to 60°C (-4° to 140°F)
  • Non-operating humidity: 10% to 90% (non-condensing at ambient)
  • Drop (out of box): 80 cm height onto asphalt tile over concrete or equivalent, 5-drop in 5 direction except the cable face
Mechanical
  • Resolution: 400 ± 20% dpi
  • Tracking speed: 25.4 cm/s (10 in/s) maximum
  • Acceleration: 2.54 m/s/s (100 in/s/s)
  • Switch actuation: 61 g nominal peak force
  • Switch life: 3,000,000 operations (using Hasco modified tester)
  • Switch type: Low force micro-switches
  • Tracking mechanism life: 250 km (155 mi) at average speed of 10 in/s
Scroll wheel
  • Width: 8 mm
  • Diameter: 2.56 cm (1.01 in)
  • Maximum rotation speed: 48 rats/sec
  • Switch type: Light force micro-switch
  • Switch life: 1 million operations
  • Mechanical life: Minimum 200,000 revolutions
Regulatory approvals
Compliant:
  • UL
  • CSA
  • FCC
  • CE Mark
  • TUV
  • TUV-GS
  • VCCI
  • BSMI
  • C-Tick
  • MIC
Feature
3.8 x 11.6 x 6.3 cm (1.5 x 4.5 x 2.5 in)
0.12 kg (0.27 lb)
Cable length
185 cm (72.8 in)
System requirements
  • Microsoft Windows 95
  • 98
  • 2000
  • Me
  • XP
  • Vista Available USB port
HP USB laser mouse
Feature
Scroll wheel
24
48 rats/sec
Switch type
Wheel
Switch life
  • Button: 3,000,000
  • Wheel: 1,000,000 times
  • Tilt switch: 500,000 times
Environmental
  • Operating temperature: 0° to 40°C (32° to 104°F)
Electrical
  • MTBF: >150,000 hrs
  • ESD: IEC-61000-4-2 criteria B, Contact discharge: +/- 4 kV, Air discharge: +/- 8 kV
  • EMI - RFI: FCC Class B
  • PC98: PC 99 Compliant
Mechanical
  • Resolution: 800 dpi
  • Tracking speed: 25 cm/sec
  • Acceleration: 0.5 mm
  • Switch actuation: 0.6 N (60 gf)
  • Switch life:
    • Button: 3,000,000
  • Cable length: 185 cm
  • PC98-99: PC99 compliant
HP USB/PS2 washable mouse
Feature
Compatibility
The HP USB/PS2 Washable Mouse is compatible with all HP Compaq Business PCs.
  • Dimensions (L x W x H): 3.95 x 6.21 x 11.7 cm (1.56 x 2.44 x 4.61 in)
  • Weight: 126 g (4.44 oz)
Electrical
  • Operating voltage: + 5 V dc ± 10%
  • System interface: PS/2 mini-din connector or USBr
  • ESD: CE level 28 kV air discharge
Mechanical
  • Resolution: 1000 ± 20% dpi
  • Tracking speed: 35.56 cm/s (14 in/s) maximum
  • Acceleration: 2 g
  • Switch actuation: 70 g nominal peak force
  • Switch life: Low force micro-switches
  • Cable length: total 70 cm + 200 cm extension (8.8 ft)
Environmental
Scroll wheel
  • Width: 6 mm
  • Diameter: 25.4 mm (1 in)
  • Switch life: 3 million operations
Approvals
  • FCC
  • CE Mark
  • ICES-003-B
  • IP66/NEMA4X
Compatibility
  • Windows Vista Business 64
  • Windows Vista Business 32
  • Windows Vista Home Basic 32
  • Windows 2000
  • Windows XP Professional or Windows XP Home 32 (No driver is required for this device. Native support is provided by the operating system.)
  • xpe
  • ce.net
  • Linux
  • XP-64
Optical storage
HP LightScribe Blu-ray Writer
Feature
Height
5.25-inch, half-height, tray-load
Orientation
Either horizontal or vertical
Interface type
SATA/ATAPI
Disc capacity
50GB DL or 25GB standard
Dimensions (W x H x D)
14.8 x 4.2 x 18.0 (max) cm
Weight (max)
950 g (2.1 lb)
Sustained transfer rate
  • BD-ROM: 26.97 MB/s (6x) max
  • DVD-ROM: 21.6 MB/s (16x) max
  • CD-ROM: 6,000 KB/s (40x) max
Burst transfer rate
  • 1.5 Gb/s bits/s (10b side)
  • 1.2 Gb/s bits/s (8b side)
Multimedia MPC-3 compliant
Yes
Access times (typical reads, including setting)
  • Random:
    • DVD-ROM: <150 ms (typical)
    • CD-ROM: <140 ms (typical)
  • Full stroke:
    • DVD-ROM: <240 ms (typical)
    • CD-ROM: <230 ms (typical)
Power
  • Source: SATA DC power receptacle
  • DC power requirement:
    • 5 V dc ± 5%-100 mV ripple p-p
    • 12 V dc ± 10%-100 mV ripple p-p
  • DC current:
    • 5 V dc - 1200 mA typical, 1500 mA maximum
    • 12 V dc -1000 mA typical, 1500 mA maximum
  • Operating temperature: 5° to 50°C (41° to 122°F)
  • Relative humidity: (operating) 10% to 90%
  • Maximum wet bulb temperature (operating): 30°C (86°F)
HP SuperMulti LightScribe DVD writer drive
Feature
Height
Orientation
Interface type
SATA/ATAPI
Disc capacity
8.5GB DL or 4.7GB standard
14.8 x 4.2 x 17.5 cm (5.8 x 1.7 x 6.9 in) (max)
Weight (max)
950 g (2.1 lb)
Access time (typical reads, including settling)
  • Random:
    • DVD-ROM: <130 ms (typical)
    • CD-ROM: <120 ms (typical)
  • Full stroke:
    • CD-ROM: <220 ms (typical)
Power
    • 12 V dc ± 10%-200 mV ripple p-p
  • DC current:
    • 5 V dc (<1000 mA typical, 1600 mA maximum)
    • 12 V dc (<1200 mA typical, 2000 mA maximum)
Environmental conditions (operating - non-condensing)
  • Relative humidity: 10% to 90%
HP DVD-ROM
Feature
Height
Orientation
Interface type
SATA/ATAPI
Disc capacity
  • Single layer: Up to 4.7GB (6 times capacity of CD-ROM)
  • Double layer: Up to 8.5GB (12 times capacity of CD-ROM)
Weight (max)
950 g (2.1 lb)
  • Random:
  • Full stroke:
  • Cache buffer: 198KB (minimum)
  • Data transfer modes: ATA PIO mode 4 (16.7 MB/s); ATA Multi-word DMA mode 2 (16.7 MB/s); ATA UltraDMA Mode 5 (100 MB/s -default)
Power
  • DC current:
Removable storage
HP 22-–1 media card reader
Feature
USB Interface1
USB 2.0 High-speed interface
1394 Interface
Two IEEE-1394a external ports; 1 IEEE-1394a internal port (connects to the pass through cable on the media card reader)
Advance protocol support
  • Supports hardware ECC (Error Correction Code) function
  • Supports hardware CRC (Cyclic Redundancy Check) function
  • Supports MS 4-bit parallel transfer mode
  • Supports MS-PRO 4-bit parallel transfer mode
  • Supports MS PRO-HG Duo 4-bit parallel transfer mode
  • Supports SD 4-bit parallel transfer mode
  • Supports high-speed 50 MHz SD 4-bit card (version 2.0)
  • Supports high-speed 52 MHz MMC 8-bit card (version 4.2)
  • Supports CF v4.0 with PIO mode 6 and Ultra DMA mode
Supported media type
  • CompactFlash Type I
  • CompactFlash Type II
  • Microdrive MultiMediaCard (MMC)
  • Reduced Size MultiMediaCard (RS MMC)
  • MultiMediaCard 4.2 (MMC Plus, including MMC Plus HC)
  • Reduced Size MultiMediaCard 4.2 (MMC Mobile, including MMC Mobile HC)
  • Secure Digital Card (SD)
  • Secure Digital High Capacity (SDHC)
  • miniSD High Capacity Micro SD (T-Flash)
  • Micro SD HC Memory Stick Memory Stick Select
  • Memory Stick Duo (MS Duo)
  • Memory Stick PRO (MS PRO)
  • Memory Stick PRO Duo (MS PRO Duo)
  • Memory Stick PRO-HG Duo
  • MagicGate Memory Stick (MG)
  • MagicGate Memory Stick Duo
  • xD-Picture Card
Supported media type with card adapter
  • Memory Stick Micro (M2)
  • MMC Micro
Environmental
  • Operational environmental extremes:
    • 10°C 10% R.H. ≥ 24 hours
    • 10°C 90% R.H. ≥ 24 hours
    • 20°C 90% R.H. ≥ 24 hours
    • 30°C 90% R.H. ≥ 24 hours
    • 40°C 90% R.H. ≥ 24 hours
    • 50°C 90% R.H. ≥ 24 hours 50°C 10% R.H. ≥ 24 hours
  • Storage environmental extremes:
    Test parameters/conditions:
    • 60°C (140°F) @ 80% R.H. for 96 hrs
    • -30°C (-22°F) @ 20% R.H. for 48 hours
  • No power applied:
    • Delta °C < 1.0°C/min
    • Delta % R.H. < 1.5% R.H./min
Approvals
  • USB-IF
  • WHQL
  • Compliant with USB Mass Storage Class Bulk only Transport Specification Rev. 1.0
  • Compliant Intel Front Panel I/O Connectivity Design Guide V. 1.3 FCC
  • CE
  • BSMI
  • C-Tick
  • VCCI
  • MIC
  • cUL
  • TUV-T
Requires the USB cable to be connected to the internal USB 2.0 port or a USB 2.0 PCI card.
Physical specifications
Feature
Dimensions
  • Chassis (H x W x D): 10 x 33.8 x 37.85 cm (3.95 x 13.30 x 14.9 in)
  • Tower Stand (H x W x D): 2.85 x 17.8 x 20 cm (1.12 x 7.01 x 7.87 in)
  • Packaging (H x W x D): 22.86 x 49.99 x 59.38 cm (9.00 x 19.68 x 23.38 in)
  • System weight: 7.6 kg (16.72 lb)
  • Shipping weight: 8.1 kg (17.86 lb)
  • Max supported weight: 35 kg (77 lb)
System volume
12.95 L (790.26 cu in)
Software/OS
Feature
Operating Systems
Preinstalled
  • Genuine Windows Vista Business (32-bit)1
  • Genuine Windows Vista Home Basic1
  • Genuine Windows 7 Starter Edition (32-bit)
  • Genuine Windows 7 Home Basic Edition (32-bit)2
  • Genuine Windows 7 Home Premium Edition (32-bit or 64-bit)2
  • Genuine Windows 7 Professional Edition (32-bit or 64-bit)2
  • Genuine Windows 7 Ultimate Edition (32-bit or 64-bit)2
  • Red Flag Linux (available only in China)3
  • FreeDOS
Supported
  • Genuine Windows XP Professional Edition
  • Genuine Windows Vista Enterprise Edition1
  • Genuine Windows 7 Enterprise Edition2
1: Certain Windows Vista product features require advanced or additional hardware.
2: System might require upgraded and/or separately purchased hardware and/or a DVD drive to install the Windows 7 software and take full advantage of Windows 7 functionality.
3: The following features are not supported on Linux certified systems:
  • HP 22-in-1 media card reader
  • HP 802.11 b/g/n wireless NIC
  • HP Serial port adapter
  • HP Parallel port adapter
Environmental data
Feature
Eco-Label certifications & declarations1
This product has received or is in the process of being certified to the following approvals and may be labeled with one or more of these marks:
  • US ENERGY STAR
  • IT ECO declaration
  • EPEAT Silver where HP registers commercial desktop products.
Energy consumption
  • 115 V ac
  • 230 V ac
  • 100 V ac
Normal operation:
  • 26.963 W
  • 26.813 W
  • 26.988 W
Sleep (Energy Star low power mode):
  • 2.529 W
  • 2.706 W
  • 2.513 W
Off:
  • 1.347 W
  • 1.507 W
  • 1.328 W
Heat dissipation2
  • 115 V ac
  • 230 V ac
  • 100 V ac
Normal operation:
  • 92.21 BTU/hr
  • 92 BTU/hr
  • 92.2 BTU/hr
Sleep:
  • 9 BTU/hr
  • 9.25 BTU/hr
  • 8.5 BTU/hr
Off:
  • 5 BTU/hr
  • 5.15 BTU/hr
  • 4.5 BTU/hr
2: Heat dissipation is calculated based on the measured watts, assuming the service level is attained for one hour.
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
